210 Gearing
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Topic: 210 Gearing
    Posted: 09 Sep 2012 at 9:36am
I am lookin for transmission gear ratios, and ground spped info for a 210, can anyone help
Pullin With AC
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 2:49pm
What size tires?
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 4:13pm
20.8x38 tires on it
Pullin With AC
JoeRepking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeRepking Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 7:23pm
what kind of rpms are you turning?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 8:02pm
The four speed transmission (if it is the STANDARD tranny) is the same as a D21. Top shaft is 24 teeth-28 teeth- 34 teeth-38 teeth.....Countershaft is 42 teeth- 38 teeth- 32 teeth-24 teeth from front to rear on all gears. Ratios are 1 to 1 in 4th gear, 1.29 to 1 in third gear, 1.86 to 1 in second gear and 2.77 to 1 in first gear.  Ring and pinion is 10 teeth to 37 teeth for 3.70 to 1 ratio. Unfortunately I can't tell you what the final drive ratio is because the Service manual or Parts books don't say. The actual ground speeds with the same tire and RPM's wind up being the same as a D21 tractor even tho the 210-220 have one more tooth (10 and 37) on the R&P pinion gear than a D21 (9 and 37). They sped up the R&P 10% and then slowed it back down in the final drives for the same ground speeds.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:33pm
Finals are 6.69? Can't remember the exact #. It is in my service manual. 5th gear (std) is in the 50:1 area, Slow 1st/5th is 73:1 area. 6th is 45:1, and 7th is 31:1, then 8th is 24:1. These are approximate, my sheets are out in the shop, and I'm too lazy! Lol!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 6:55am
You'd be keerect Ed!!...I looked at an Owners manual this morning and it doesn't give an actual tooth count, but the finals are 6.69 to 1 ratio. So, the tooth count must be 15 to 100?? or 16 to 107??...if someone has one apart, I'd like to know so I can write it in my Service manual.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 12:50pm
Thanks for the help
Pullin With AC
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 10:52pm
DR. are you wanting the bull pinion drive and bull gear tooth count?
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 5:49am
Were the range transmirssion and low gear options  for the 220 also offered on the 210?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2012 at 6:31am
yes, most 210's either have "slow first & fifth", and a few (mine included) have the "fast low range" .
