Fuel sediment assemblies?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Fuel sediment assemblies?
    Posted: 08 Sep 2012 at 10:51pm
 Trying to figure out the correct fuel sediment bowl assy for the D10-12 . Can't really tell from parts book on which is correct. When you order one now, most are generic in nature. Was the inlet offset to the casting and bowl? Was outlet 90 degrees or 180 degrees from cutoff valve. Did the originals have a plug in one of the outlet holes? Thanks Tracy Martin
