Finish Mower Brand Difference? Opinions Needed!
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Finish Mower Brand Difference? Opinions Needed!
    Posted: 06 Sep 2012 at 12:45pm
Just purchased a 33 hp Kubota diesel tractor and now want to get a new 3pt finish mower for it.  I have looked at the King Kutter ones at Rural King 5ft and they run around $1350.  The dealer where i bought my tractor sells Land Pride 5ft ones for around $2000.  Besides for price what is the difference between the mowers?  I want a decent mower that will last me a while.  Not mowing a ton of acres by no means, but a few.  Let me know your experiences.  Thanks Steve-Ohio
Edited by Steve-Ohio - 06 Sep 2012 at 12:49pm
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 12:54pm
i would look around and find me a old woods with a good belt and not look back, you can pick them up for 4-600
i like old tractors of all colors
ac45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 1:01pm
Steve, I have a 6 ft Rural king brand in real nice shape that I would take $650 for . The blades are sharp and it is ready to go.  i used it with a tractor  i no longer have. We bought a zero turn mower and dont use it much any more. I can text pictures.  Im around North Vernon IN 812 528 7718
Edited by ac45 - 06 Sep 2012 at 1:02pm
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 2:57pm
Spend a little more and get the landpride or woods! After selling many brands of them over the years, I prefer Landpride for many reasons. Our current LP finish mower is over 15 years old and still on orginal spindle brgs and wheel brgs.  We have hit and busted a couple spindles but we keep it greased every week on wheels and once or twice a month on spindles. If you mowed with both (or any of lower cost ones) you would see the difference in them!
Edited by farmtoybuilder - 06 Sep 2012 at 3:01pm
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 3:00pm
I have a 7' King Kutter that I bought used 8 years ago, and the only things I've replaced are spindle bearings. I attribute that to previous owner not keeping them greased, because I grease every other time that I mow. It's been a good mower for me.
1950 WD, Duetz Allis 613
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2012 at 5:32pm
I have used Woods mowers for over 30 years and am very happy with them.
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 4:42am
I bought a king kutter (brush hog, not a finish mower) and used it for 7 years until the farm shut down, the neighbor bought it and is still using it. we cut 10 acres of hay and used it to cut another 2 acres of just scrub brush. I only wish I would have known they had a brush hog that has a hay side. I guess there is a plate you can take off so the hay comes out the side.
Edited by dt1050 - 07 Sep 2012 at 4:46am
allischalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmers Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 6:02am
I have a john deere 61in for sale $500 its like brand new
WD45,C,3 B's
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 6:26am
I've used a 5' King Kutter for the last 5 years and it mows great and I have not had one single issue with it.
I mow about 2 acres.
Charlie
rickwsomd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rickwsomd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2012 at 10:18am
We have two Land Pride finish mowers.  Both are 6 ft.  One is probably 15 years old, the other is maybe 8.  We picked up the second one because a friend was getting rid of it for a price that was too good to pass up and we wanted something in case the older one went belly up.  I guess we will have two for a long time, cause they are built great and do an awesome job.  We cut 6 or 7 acres from spring to fall and have had no trouble.  Have only replaced blades and belts as needed. Take Care, Rick
Rick W.(So.MD)
David Grubb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Grubb Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2012 at 9:07pm
I bought a year old Woods 6' RD72 last year and am disappointed with it. The wheels are the solid rubber type which is ok, but the wheels use bushings instead of bearings and I've gone thru 3 wheels already.
Dave
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 7:21am
I use a Bush Hog model ath99. It is a 7 1/2 ft. finish mower. It is one heavy dude. Not cheap. I had a Keen Kutter, had to work on it all of the time. Bending blades, trying to keep air in tires equal. The Bush Hog has never bent a blade and in ten years have only had to sharpen twice. Tires are solid, no scalping.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2012 at 12:43pm
I use a 72" woods.  I would not buy anything smaller if I were you.  Woods is probably the best in my mind, but if I bought another my main point of interest would be if it's rear discharge.  Rear discharge, the greatest improvement made to finish mowers in years!
