WC hand clutch.
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: WC hand clutch.
    Posted: 30 Aug 2012 at 7:09pm
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 7:18pm
Do you know the year of the tractor?
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 7:21pm
   Has a belt pulley shutoff and foot brakes, too. Cool
Edited by Rfdeere - 30 Aug 2012 at 7:23pm
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 7:22pm
The owner said its part 38 and part 39. Its an after market clutch made for the roto baler. Its a dry type.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 7:22pm
  aftermarket   have seen others also
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 7:50pm
There's that tiny little WD-45 again!!
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 8:13pm
That's about the neatest WC ever!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 9:17pm
That is a X-TRA clutch made for roto baling by Sudenga Iron Works in George IA.
A few years ago on their website they listed that clutch a one of the first products manufactured by them. Brian Ahart has a copy of a brochure on his website.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 10:27pm
All the things I see as extra's on this tractor were available through Tractor Supply.  The belt pulley shifter, the hand clutch, the foot brake conversion, the extension on the clutch linkage to make it push easier, and the fix-it-kit for the shifter, and the easy ride seat, were all listed in the older catalogs.
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2012 at 10:31pm
i've got one of those hand clutches, i would sure like to get a copy of any lititure on one. i also have a belt pulley shut off but mine looks to be a different mfg.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 4:11am
look at the steering wheel i wonder if its original
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 5:34am
On the first picture, I see a single front high clearance with black bar grill. You wouldn't have a picture of it, by chance?   Dave.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2012 at 5:36am
We have that same hand clutch on our 38 WC. Always wondered who made it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 7:42am
I have an old Tractor Supply catalog from 1959 that shows that clutch for sale.
Many years ago at the Orange Spectacular, Dave Ferguson and I took the top off a hand clutch, high low set up that had a clutch that ran in oil much like the hand clutch on a WD, but this one also had a two speed gear box.  It was on a WC.  The only one like that either one of us had ever seen.  There were no markings of any kind on it, or even any casting numbers we could see to help identify it.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2016 at 4:52pm
I overhauled a styled WC for a guy about 30 years ago it had high and low range plus a live power clutch a neat set up. Any one on here got any pictures of that mini WD45 I don't think i have seen that one before.
turbocharged
This page was generated in 0.270 seconds.
