ford diesel blow by
Bolivar Boy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bolivar Boy Quote  Post ReplyReply Direct Link To This Post Topic: ford diesel blow by
    Posted: 28 Aug 2012 at 9:01am
we have this sweet little tc 55 ford new holland diesel bucket loader/hoe tractor with 700 hrs on the clock that was purchased 2nd hand from original owner. we use it around the ford car truck dealership im service mgr. at. the machine has accumulated 200 hrs, now at 700 hrs since we purchased it 3 years ago. yes it gets serviced to death using only ford/new holand filters and ford 10w40 dsl oil. we trenched a footer for one of our buildings. pushed dirt etc this summer. all of a sudden this little 4 cyl is pushing oil fumes out the breather and of course its pushing out fumes at the oil fill if you pull the cap. this is a little turbo engine. engine starts right up ,runs smooth. has full power. coolant not down, oil not down. changed oil and filter on saturday, no residue in oil. no blowing the blues during operation or at start up. no oil in antifreeze. engine not running hot. will probably do a compression check first step........have any of you been around these units and experienced similar issues? and what was the fix.........im guessing a turbo issue......please let me know. thankyou....tp studer (bolivar boy) wooster,ohio.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 11:31am
It wouldn't be turbo if it's coming out oil fill or crankcase breather. Check compression, maybe broken rings? Has it ever been hot? Those motors dont' like being overheated.
You might want to check air filter and all tubing-hoses going to intake. Pull off hose or tube at intake and see if it's clean or if its dirty. Had some with bad filters and one hose connection was loose and sucked dirt into engine!
Edited by farmtoybuilder - 28 Aug 2012 at 11:37am
