1938 ac b
jeffsh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Topic: 1938 ac b
    Posted: 26 Aug 2012 at 8:41am
i have a 1938 ac b with mag ignition,either hot or cold it will not start by hand crank,pull it a few feet and it starts fine,always runs great after started,any ideas?
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 9:01am
Can you hear the impulse coupler snapping over when you hand crank it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 9:51am
i do hear a snapping noise from the mag
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 9:54am
i'd check the points
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 10:10am
points eventhough when pulling starting it it starts right up & runs fine?
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 10:12am
ya i've seen that be the problem...of course i too the mag off my c and swapped to a distributor form a ca
DaveKamp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 11:40am
Consider the difference between hand-cranking, and pull-starting... the speed at which you're turning the crank.
What would make it sensitive to speed?  One of the most obvious, is the rate at which the magneto is spun.  The impulser's job is to 1) accellerate the rotor's spinning velocity to generate a high spark voltage and 2) delay the ignition event until AFTER top dead center, to a) prevent kickback and 2) assist in starting.  Insufficient spark voltage is frequently a major problem in poor starting.  Keep mind that you may observe what seems to be a good spark, is frequently NOT enough to light off a starting charge.  At slow engine speeds, the fuel mixture is frequenty very very lean, which takes an extremely powerful start to light off.  The best spark, is a bright blue snap that makes a strong man fear it's wrath.  Frequently, a weak spark from a magneto is caused by problems with contact points, condenser, or 'phasing'... the timing relationship of the points opening, with the rotor's angle to it's windings.  Sometimes it's weak magnets or a magneto coil with failing insulation in it's windings.
Another thing that contributes to cranking velocity, is the ability of the engine to draw in a suitable charge for firing.  When starting, there isn't much draft velocity, so getting sufficient pressure differential across the venturi so the choke provides restriction that causes manifold pressures to fall low enough to 'pull' fuel up and out of the fuel jets from the float bowl.  A low float-level in the fuel bowl, or fuel jets that have atomizer holes that are plugged, or a crack in the bowl or carb casting can prevent proper intake charge.  Another thing that is frequently overlooked, but will cause such problems, is a manifold leak... either to atmosphere, or to the exhaust side.  Amidst these tractors' ages, such cracks are not unusual, and can be pretty well hidden inside somewhere.
Valves that don't fully seat, or a worn engine being very low on compression can also prevent starting.
How to figure this out?
Trial and error.  This is where having a 'herd' of similar tractors is really handy.  I know which of my tractors has the best carbeurator and manifold, best magneto, etc...  and to determine the cause of a problematic guy, I borrow the best carb, and put it in place.  If that doesn't sovle it, I substitute the best magneto.  If, at that point, neither solves it, I look to valves, manifold, and compression.  Typically, I'll find the issue quickly, rebuild or replace the weak component, and be in good operation immediately.
Post Options Post Options   Thanks (1) Thanks(1)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 1:29pm
This will start a fire storm of criticism but I test a mag by pulling all the wires out of the cap, place your palm over where the plug wires go in and slowly crank it over. If you have enough spark to jump the gap and bite you, you'll have enough spark to start and run the engine. Quick and easy.
Dave Everett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 3:29pm
id start with the manifold gasket......tugging creates a strong vacuum the pull the gas in, cranking should if you dont have an air leak...................been there     done that !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 4:40pm
what shoud i expect or should i say get for compression readings on a good engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 4:42pm
tell me more about phasing of the points,correct piont gap?
Dick L View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 4:59pm
Probly a weak spring or rounded pawls in the magneto impulse. When hand cranking the spring has to spin the armature fast. I have had rounded pawls that would click but still didn't load the spring enough when they slid by the pin to soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 8:18am
pease tell more about the phasing of the points,what is the correct point gap?what should compression be?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 9:45am
Phasing of the points and point gap is something that is best described when you've got a  magneto apart, on the bench, with the mag service document in front of you.  Sometimes it's covered in service books, but most times it's something explained by a magneto guru who's pointing it out... but I'll give you the best explanation I can, without having said items before me.
A simple type of magneto, is the kind that shows up on... say... an outboard motor... a mid '20's Evinrude.
There's a magnet in the flywheel... and the flywheel is spinning.
There's a pickup coil on a plate benenath the flywheel, and the magnet zips by it.  The whole plate rotates in order to allow the spark timing to be advanced or retarded... because on a 2-stroke outboard motor, timing pretty much determines how fast that motor will spin.
Inside the coil is two windings... a primary (higher current) and secondary (lower current) coil.  They're grounded at one end... the secondary goes to the plug... the primary goes to contact points.
When you place a coil IN a magnetic field quickly, the coil and polepiece have to 'accept' that magnetic field, and for a very short time, there's an imbalance between the coil, and the magnetic field, and as a result, you'd get some voltage appearing across the coil.  If you had some sort of a load between the ends of the coil (or coil and ground, since most coils are grounded at one end), then you'd have current flow.
If you yank that coil OUT of the magnetic field, the exact same phenomena occurs... the field which was 'accepted' into the coil, has been yanked out, so the field around the coil collapses, which induces action in the coil.
Back to the outboard motor... If you had just the secondary, as that flywheel spun by, you'd have a spark... and the spark would be visible at speed, and you'd feel it, but it'd be pretty lame.  Reason is simple-  the magnetic field builds as the flywheel comes closer, and falls off at the same rate at which it arrived... slowly.  Of course, the faster the flywheel cruises by, the faster it rises, and falls, so you get a more aggressive spark.
Now... let's modify the design, and add a second layer of wire to the coil, and call it the PRIMARY.  Let's short both ends of the primary, or leave them open, and spin the flywheel... we get exactly the same action as we saw before... but since there's more wire in that coil, the magnetic field occurs in a greater intensity.  Now, let's put a SWITCH in that secondary (call them 'points')... and just as that flywheel comes through, but just before it starts falling off... let's open the points!
What this does, is build that magnetic field as it normally would, but at a much higher intensity... and then by interrupting the primary, the entire magnetic field (built in both the primary and secondary) must discharge through the secondary AT THE SAME TIME!
This causes the magneto to create a much more intense spark, strong enough to burn oil and fuel residue off the plugs, and ignite not only a wet, but also a very lean mixture.
Now... let's say there's something wrong with alignment in the points... the cam lobe is worn off, or something like that...
The flywheel comes by... the points open about 5 degrees AFTER the magnetic field has passed...
Yeah, there's spark... we can feel it, we can see it... but it's sissy.  She'll run when you pull her, but when you hand-crank it, it won't start.
Also... to keep those points from burning, there's a condenser in there... it's a 'buffer' or a 'cushion' of sorts... it provides protection from the points because that collapsing field will WANT to jump the gap of the points at the moment they open.  Of course, this burns the contact points, but worse yet, it means the points really didn't open... hence, a lousy spark.  As the engine gets going faster, the magnet comes by faster, so she still runs fine... but with that arcing going on, you get an unstable spark, so she may run fine sometimes, and other times, she's lousy.
Now, let's say the point cam is worn... it ALWAYS wears on the 'climbing' side, more than the falling side... particularly if it's full of abrasive dust, wasn't properly setup or lubricated... or just sixty-eight years' run without a rehab.  That cam lobe's face has worn enough so that the actual point OPENING time is not lined up with the magnetic pass's departure... it's LATE in opening.  Lousy spark.
A magneto with an impulser not only gets a really quick spin of it's armature, and after-TDC spark for starting assistance and kickback, it also is less susceptible to hard-starting amidst degradation of the ignition points, point cam, and condenser... since it's whipping it over fast, you could have a well-worked setup that still kicks out a good enough spark to run... and never notice much change.
Hence, I suggest you grab a mag off of another machine that DOES hand-start well, stick it on, and see if your B will hand-start.  If it does, give your magneto a healthy going-over... or if you've got a local guru who's made an investment in the special tools for rebuilding magnetos, throw him a bone, bring a couple of beverages, and observe the maestro at work.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 10:01am
Compression and manifold leaks...
Second things first:
If the engine is running... a squirt bottle of something is one of the best 'tricks' for finding a manifold leak.  I've seen guys use an unlit propane torch, WD-40, carb-cleaner, fogging oil... and the idea is all the same:  Spray it in the vicinity of suspected leaks, and the engine's running attitude will change... because the stuff's being drawn in.
Compression:
These are lower compression engines, so naturally it shouldn't take alot to get 'em to fire off... but when an engine is 'rate sensitive' for starting, it's likely that there's enough 'leak down' at low speeds to prevent draught (drawing fuel and air from the carbeurator), or not enough pressure building to cause a cylinder to hit hard enough to throw it through the next cylinder's cycle.   I wouldn't be so bold as to just put a pressure gauge suggestion up, because it's not necessarily telling the whole story.  In any hand-start engine, you need to be able to grab the flywheel or crank, and pull it across TDC. On a fresh rebuild, there's enough friction and compression that will make you NOT want to hand-start it.  Typically, after a good break in, it will cross TDC because you PULLED it up to it, then 'flipped' it over.  If you pull the crank, and very clearly FEEL compression, and when you stop pulling, it pulls BACK a bit, you have enough to hand-start it.  If you pull it to resistance, then stop and let it leak down... and then pull a little more... then you'll have a tough time getting it to hand-start.   Never grab the crank of an engine and just spin it like an antique phone ringer... that's an excellent way to get hurt by a kickback... if you can do that with your B (and it's very unwise to do so), then it's time to turn the crank slow and listen in four places:
1) Intake.  Hissing out the intake suggests intake valve leaks.
2) Exhaust.  Hissing out the exhaust suggests exhaust leaks.
3) Crankcase/valve cover.  Hissing out the crankcase or valve cover suggests leaks past the rings
4) Radiator.  Hissing or bubbles out the radiator suggest a failure either in the cylinder head, head gasket, or cylinder liner.
MOST of the time... (and this is in my personal experience not only in AC, but in ALL engines)... that a failure to hand-start  on engines, can be resolved by giving the mag a good rebuild, and if that doesn't totally cure it, pull off the head, clean up the chambers, renew the head gasket, pull, wire-brush, and lap the valves.  Even with well-worn cylinders, they'll hand-start with just that little freshening up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2012 at 10:06am
let me ask you this,i watch a video on rebuilding mags.they remagnitized it,when they were done they were able to pick up a ballpeen hammer with it.while i dont have mine completely disassembled,if i lay a screwdriver on it it barely sticks,sound weak?i have nothing to compare this with as its my first tractor.
George Davenport View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote George Davenport Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 10:45am
Thank you Dave Kamp for your time and depth of discussion on this thread.
Life is what happens while you are making plans for the future
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffsh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 10:54am
much thanks dave kamp for all of the great info.loved the detail & the simplicity of your explanations.now i feel i know a little about these old tractors,hope to llearn much more.
ACJohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACJohn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2012 at 2:12pm
This is worth repeating...Dave- AWESOME explanation!
