CA Hand clutch part
jaredgoforth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaredgoforth Quote  Post ReplyReply Direct Link To This Post Topic: CA Hand clutch part
    Posted: 25 Aug 2012 at 11:16am
ok my 1953 ca needs hand clutch rebuilt, and on ebay their is the complete assemble took out of a ca says it is in working order they want about 30 dollars shipping and all do you think it is worth the risk?
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 12:33pm
I would rebuild the one you have , then you know what you have and a reliable one. If you don't want to rebuild it your self , send it to Sandy Lake Implement.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaredgoforth Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 12:51pm
i may send it to them to make sure its done right i didnt know they would do it for you
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 1:43pm
Does your hand clutch slip...or is it frozen? Used hand clutches are hard to come by (especially decent rebuildable ones), and generally expensive when located.
Rebuilding a hand clutch is not that difficult (especially once you have it on the bench). A good shop press, a rivet setter, some feeler gages, Allen wrench for the 1/2 cap screws, and a machine shop with a good lathe (and operator) makes short work of the task. Rebuild parts (friction, rivets,springs, and balls) are readily available.
I can send you two pdf files with pictures on how I rebuild the clutch; pm me you regular email address and I will send them to you.
