AC 6ft BLADE ?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: AC 6ft BLADE ?
    Posted: 23 Aug 2012 at 10:59pm
When were thre AC 3pt blades blt?. and was there only one model of blade that AC blt. i have one SC. and one 3pt. both are the same basic blade only diferent hitches.Thay are the (Oxnard blades).
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 3:34pm
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 3:49pm
Tom the blades changed a bit over the years, but basically the only difference between the snap coupler and 3 point versions was the hitch.  I have an Oxnard book that shows the verious changes from start to finish.  Michael
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 8:30pm
They built a newer version of the 3pt blade but it was lighter and you had to use the 3pt arms on the tractor to tilt it as there wasnt a wheel on it ,and the rear moldboard tilt was done with straps instead of scews
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 9:55pm
Thanks guys. dose anyone have any pics of the new style blade thay could post?? Thanks Tom. PS. was the newer blade blt. by Oxnard?? thanks
Edited by ctbowles58 - 24 Aug 2012 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 12:32pm
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 4:56pm
Here is a picture of my A-C 86 rear blade (6' model).  This is one of the later model A-C rear blades.  It is a heavy built Category-II blade, but I changed out the pins to Category-I in order to use it on my D12.
Model 86 brochure from October 1971:
A-C Weight ID reference and other goodies at brianahart.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2012 at 7:34pm
thanks i neaver seen one of these before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 9:38am
we have the 8 foot version, ct if you ever get to the central mo area call me and stop by, I have a little junk to look at, Dustin
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2012 at 1:44pm
 I have a blade just like that  I got with a D15 series II its a 3 point. Thanks for the pic of the literature, always wandered what the number was for it.
                                                   IG
