Very nice Allis + Duetz Allis coming up at auction
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Very nice Allis + Duetz Allis coming up at auction
    Posted: 23 Aug 2012 at 6:16am
Nice tractors com
Auctioneer
Schneider Auctioneers, LLC (Formerly Schroff Auctions)
573-834-2207
Auction Date
Sep 07
Auction
Location
12881 County Rd. 4039
Holts Summit, MO
Click to Map
Time
09:00AM
Auctioneer's Other Listings
E-mail Auctioneer
Auctioneer's Web Site
View Photo Gallery
Auction Listing
AuctionZip Auctioneer ID# 6268
Auction Brochure (PDF)
Eikermann Farm Retirement Auction
Friday, September 7th, 2012 - Starting at 9:00 AM
Location: 12881 C.R. 4039, Holts Summit, MO. From the intersection of Hwy 54 & 94, just north of Jefferson City, MO., go east on Hwy 94 3.2 mi. Turn left on C.R. 4037 and go .5 mi. Turn left on C.R. 4039 and go .3 mi. to Auction Site. Signs will be posted Auction Day.
Simulcast On-line bidding will be available on tractors, combines & some other items.
Note: Due to the health of Stanley Eikermann, he and his wife Norma have decided to sell all of their farm equipment, as well as other items related to their farming operations. Also on the auction will be collectibles, antiques & furniture from Stanley's fathers farm in Morrison, Mo. which have been in storage for nearly ten years. This will be a HUGE auction, there will be something for everyone. We will be running two auction rings nearly all day.
Terms: cash, check with proper ID, Visa, Mastercard, Discover credit & debit cards accepted. Out of state checks & all checks over $2,000 will require an original irrevocable bank letter of guarantee (NO Copies) unless pre-approved by Auction Company. If you do not bring bank letter of guarantee, equipment will remain in Sellers possession until check clears. Nothing to be removed until settled for. Everything sells AS-IS, WHERE-IS. Not responsible for accidents. Announcements made day of auction supersede any & all advertising.
Tractors • Trucks • Farm Equipment • Trailers
Note: We will start selling equipment at 11:00 AM. We will sell lots 1-11 first, and then sell the remaining trucks & equipment. Items 1-11 will be available for simulcast on-line bidding on www.bidspotter.com. All tractors, combines & trucks have new batteries, tractors have new filters.
Lot 1) Deutz-Allis 9190, FWA, CHA, 3-remotes, 1000 pto, 18-spd. trans., 3,044 hrs., matching Firestone radial all-traction-23 axle mount 18.4-42 duals & 16.9-28 fronts, front weights,SN-9190F2057
Lot 2) Deutz-Allis 9190, FWA, CHA, 3-remotes, 1000 pto, 18-spd. trans., front fenders, matching Firestone 20.8-38 rice & cane axle mount duals w/18.4-26 fronts, showing 870 hours, true hours unknown, front weights, SN-9190F1316
Lot 3) Allis Chalmers 8070, FWA, CHA, 2-remotes, 12-spd. power-shift trans., 1000 pto, 3,629 hours, like new Firestone super all traction-23 axle mount 20.8-38 duals w/14.9-28 fronts, 11 front weights, SN-4866
Lot 4) Allis Chalmers 8030, FWA, CHA, 2-remotes, 10-spd. trans + creeper, 540 & 1000 pto, 2,359 hrs., 10 front weights, 20.8-38 inside rears w/18.4-38 axle mount duals & 14.9-28 fronts, SN-5252, bought new by the Eikermanns
Lot 5) Allis Chalmers 6060, FWA, w/AC 460 loader, 8-spd. trans., 540 pto, ROPS w/canopy, 2361 hrs., 18.4-28 rears w/11.2-24 fronts, loaded rear tires & rear weights
Lot 6) 1979 Chevrolet C65 grain truck, single drive axle w/air tag, 427 V8 gas, 5+2 trans., 18’ Knapheide grain bed w/hoist, 52” steel sides w/12” steel extensions, 10.00-20 tires
Lot 7) Gleaner N6 combine, 2wd, 30.5L-32 tires, showing 1563/2421 hrs., SN-N6G02212H
Lot 8) Gleaner N5 combine, 4wd (not working), 30.5L-32 cane & rice tires, unknown hrs., SN-5G03288H
Lot 9) Gleaner N6 combine, 4wd (not working), 30.5L-32 cane & rice tires, unknown hrs., SN-6K04255H
Lot 10) Daewoo DSL801 skid loader w/bucket, 990 hrs.
Lot 11) 23’+5’ gooseneck flatbed trailer, 102” wide, steel floor, dual jacks, 7k axles w/8k suspension, 14-ply tires, ramps
-’88 IH single axle road tractor, DT466 eng., 10-spd. trans., spring susp., showing 261k mi.
-’79 Chevrolet C70 dump truck, 427 V8 gas, twin screw, 5+3 air shift trans., 14’ bed, hauled rock this year
-’74 Chevrolet C65 dump truck, 427 V8 gas, twin screw, 5+3 trans., 13’ bed
-’80 Fruehauf 28’ single axle van trailer, roll up door
-Great Plains solid stand 20’ no-till drill w/caddy, some broken seed feeder belts
-JD 8300 13’ grain drill
-Bush Hog V-ripper, 7-shank, 3-pt., gauge wheels, 2’ shanks & another unknown brand ripper
-AC 1300 35’ field cultivator w/harrow
-AC 32’ field cultivator w/harrow
-AC 30’ field cultivator, needs repair
-4-bi-fold JD discs: 2-22’ mod. 230’s w/20” blades • 25’ mod. 235 w/24” blades & wing tires • 28’ mod. 330 w/24” blades & wing tires
-Bush Hogg 20’ disc w/spring over wings, one wing dis-assembled w/parts to fix
-AC 14’ wheel disc
-AC 2000 6-16” semi-mount plow
-Oliver 565 6-16” semi-mount plow
-JD 2350-2450 6-16” semi-mount plow
-Oliver 575 4-16” semi-mount plow
-AC 4-16” 3-pt. plow w/1 bottom removed (with plow)
-Krause 298 10’ chisel plow, 3-pt. w/harrow
-JD 825 6-row cultivator, 3-pt
-JD 400 15’ rotary hoe
-2-Gleaner 6R-30 corn heads
-4-Gleaner 20’ grain platforms from useable to parts machines
-Speed King 6”x32’ grain elevator, hyd. remote drive & another 8”x48’ pto elevator
-Rhino HD 3-pt. 8’ blade
-Move-Master header cart & another homemade
-3-pt. anhydrous tool-bar
-3-pt. chisel plow made in to rock rake
-NH 256 hay rake
-Bush Hog 6’ pull-type rotary cutter w/cylinder
-3-6’ 3-pt. finish mowers: 1-Bush Hog ATH-720, 1-woods & 1-Challenger
-Bush Hog PHD w/10” auger
-NH mod. 132 hay elevator
-4-flatbed farm wagons w/grain sides
-2-16’ flatbed utility trailers, 1-with title & 1-homemade no title
-3-pt. 110 gal. sprayer w/28’ boom & another 3pt. frame & tank
-3-pt. post driver
-Drawbar mount spreader
-IH 175 crawler loader, power-shift, for repair or parts
-JD 1460 discbine for repair, broken cutter head bar, has good bar with it
-AC 6-row corn planter for repair
-JD ground drive manure spreader
Tools • Farm Supplies • Lawn & Garden • Parts • Misc.
-JD Hydro 165 lawn tractor, 38” cut
-Welders: Lincoln TM400 commercial stick, Lincoln 225 amp stick, Forney C-6 stick & Cemig 170 mig for repair
-Arc Torch 2000
-Oxy-Acetylene torch, hoses & brazing tips
-Assorted welding helmets & supplies
-Carolina 30-ton hyd. press
-Craftsman 10” radial arm saw
-Craftsman 12” band saw
-Coleman Pulse 1750 generator
-Solar 450 HD battery charger
-Bench grinders
-Large assortment of hand tools incl. clamps, pry bars, pipe cutters, tap & die sets, ¾” drive socket sets & impact socket sets
-7-electric drills & 2-electric impact wrenches
-B&D 18V cordless drill
-Shop-vacs
-Bench vises
-Hydraulic jacks
-Large assortment of hand carpenter, farm & garden tools
-Several gas engine water pumps
-Manual tire changer
-4-sets of tractor duals & 2-sets combine tires & rims
-3-new high torque Dayton 1 hp. electric motors & others
-Assorted fuel barrels & stands, hydraulic cylinders, combine dual wheel adapters, wheel weights, brush hog blades, planter & tillage equip. parts, steel & wood fence posts, implement rims & tires, fence wire, split rim truck tires, skylights for metal building, disc blades, HD rubber tarp material & vinyl truck tarps, poly tanks, baler twine, boxes of nails, pulleys & sprockets, hardware, pvc couplers, tire chains, organizer cabinets, casters, joist hangers, pto pumps & sprayer parts, copper wire & sickle guards
-Truck toolbox/fuel tank combo & other truck toolboxes
-15-gal. hand pump oil dispenser
-Set of Rockwell twin screw axles & suspension
-2-cattle guards
-Electric fence supplies
-1000 gal. propane tank
-2-smaller anhydrous tanks
-4-10’L x 14’H galvanized sliding shop doors
-2-Baughman grain bin dryers
-Dole grain moisture tester
-Fertilizer boxes
-AC WC grille
-Forklift mast
-3-new dusk to dawn lights
-2-older garden tillers
-Snow blower
-Yard seeder/spreader
-Garden push plow & 2 walking plows
-3.5’ pull-type garden roller
-Outboard motors incl. Jetstream 255, Mariner 30 & Evinrude Fisherman (no-title)
-8-live traps
-Chicken feeders & cages
Collectibles
-R&W Co. Cylinder wooden butter churn
-Enterprise #22 bench meat grinder & 1 gal. sausage/lard press
-Crock jars incl. Western Stoneware 10 gal., Red Wing 4 gal., Buckeye 3 gal., White Hall 2 gal. & others
-Fulton hand corn sheller
-Hay fork trolleys, pulleys & grapple forks
-Egg case & 4-yellow wire baskets
-3-yard or garden gates
-Antique hand tools
-Old steel leg traps
-4-standing leg vises
-Folding baby carriage
-2-glass oil lamps
-Justrite carbide skaters lamp
-Chalk 28” Santa
-2-qt. glass butter churn
-4-qt. cream can
-Embossed Crystal Water 5 gal. jug
-Brown & white swirl 2 gal. coffee pot
-Iron cook pot
-Kraut cutter
-Assorted early blue fruit jars & clear mason jars w/lids & bails
-3-lb. coffee jar
-Old Judge coffee jars
-Apothecary jar
-Picture frames
Household • Glassware & Furniture
-Bachelor’s chiffonier
-Slant front secretary
-Maple 5-pc. bedroom set
-2-decorative iron beds
-Flat top trunk
-Metal lawn chairs
-Upholstered furniture
-Antique floor lamp
-2-pink Miss America sherbets
-4-pink horizontal water glasses
-2-pink berry bowls
-Pink glass cookie jar
-Green depression pitcher
-2-large Royal Ruby vases & 2 small
-Fire King white w/gold trim cups, saucers & berries
-7-Sheffield bone white china plates
-Crackle glass drink shakers w/silvered top, Germany
-Misc. pots, pans & cookware
-2-color tvs
-Sears portable wash machine/pot
-Magnavox surveillance system, NIB
-Numerous Other Items
-Sellers: Stanley & Norma Eikermann
-Lunch Available
Auctioneer License Information: MO-611 / IL-441.001687
    Auction Listings provided by AuctionZip.com. Although the information published herein is from sources deemed reliable, AuctionZip.com expressly disclaims any liability for errors, omissions or changes regarding any information provided for this auction. Potential buyers are urged to verify auction date, time, and content directly through the auctioneer's website or by contacting the auctioneer directly. The terms and conditions of the auction may or may not be published in this listing. ALL TERMS AND CONDITIONS AND OTHER ANNOUNCEMENTS MADE THE DAY OF THE AUCTION ARE BINDING AND TAKE PRECEDENCE OVER ANY INFORMATION FOUND HEREIN.
Join Our E-Mail List
Receive notifications of our upcoming auction listings.
E-Mail:
First Name:
Interested in Auction Types:
Auction Search
Auction Calendar
Auctioneer Directory
Prices Realized
Online Bidding
Upcoming Auctions
Online Bidding Tutorial
Online Bidding Help
Quick Links
Create Account
Auction News
Auction Forum
About Us
Contact Us
Link to Us
Advertise with Us
Follow Us
Follow Us
Like Us
ing up on September 7 in Holt Summitt MO
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 6:32am
Link to Auctioneer Website:
Gary
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 6:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 6:49am
Thanks Gary, couldnt get that to load for some reason
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 6:59am
Wow -- some really nice stuff -- hate to see a farmer's operation end like this ---
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:11am
Nice stuff there!
Charlie
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:27am
Really nice I'd love to have the 6060
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:30am
Wow, those tractors look like new except for the tires.
HD16,917H,185,7050,8030FWA,8050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 7:34am
Anyone interested in anything Im close and can check it out for you and have a place for them if needed for a bit
Edited by DougG - 23 Aug 2012 at 11:19am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 11:00am
I wish.
Looks like all his tractors were FWD.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2012 at 11:12pm
Love that 6060 w. the loader
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 11:56am
I would like to see them in person.  The 8070 and 8030 have both had the rear window replaced (no A-C logo) and are both missing the RH cab steps.  Look to have a different brand of lights on the cabs, too.  Have to wonder on the tach hours when you can notice little things like this from a web photo.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 2:20pm
Russ not arguing your point as they are good one. But I am sure the right step was taken off to get to the batteries better. There probably there on the farm somewhere. And the lights,probably bought them at a parts store for  1/3 the price.  What caught my eye, is how would all of those tractors all have such good paint,and all have the same color in every pic. Almost look photo enhanced. Would love to go to the sale,but will be right in the middle of corn harvest
                                                      IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 2:29pm
The 6060 and 8000 have at least been partially repainted.  The FWA lug nuts are white and the rear rims on the 6060 are now white, not silver.  Not saying they are bad tractors and I'd dearly love to have an 8070 to go with my 8010.  I just look at cab interior and missing accessories to judge the over-all care a tractor may have received.  At nearly 30 years of age they are almost all due to have the paint touched up.  Not sure where the auctioneer got his serial numbers, either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2012 at 6:22pm
I did notice on the Lot 3 pic that then duals look taller than the drive tires? ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2012 at 2:56pm
Just a bump on this auction ,im heading up there if anyone far off is interested in anything
Edited by DougG - 04 Sep 2012 at 5:50pm
