180 running bad/ cutting off
Revjsu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Revjsu Quote  Post ReplyReply Direct Link To This Post Topic: 180 running bad/ cutting off
    Posted: 21 Aug 2012 at 6:18pm
I have a 1969 180 Diesel. I have had issues with it sputtering then eventually shutting down. I have plenty of Diesel, sediment bowl is clean, I try to bleed it with the hand pump, but it takes forever, when I finally get diesel flowing out of the the hole on top of the filter housing, it will start up, run for a minute or so, then it stops again. Open the hole of top of the filter housing, start pumping with hand pump, and it seems to have air again. Help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 8:05pm
Remove the sediment bowl again and turn on the petcock all the way. There should be TWO streams of fuel gushing from the center of the base. If there is only one stream straight down, the base if plugged with debris and needs to be removed and cleaned at the inlet.
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 9:39pm
I had the same problem on my 185.   I messed with it for a month, draining, bleeding etc.   Turns out it was the strainer/filter in the sediment bowl.    It looked ok but fuel wouldn't go through it.   2 bucks later and it runs great and keeps on running.
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2012 at 9:41pm
Throw the screen away.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 3:08am
<<<<<agrees with DrAllis...my problems stopped when i did that! you have a filter on there, let it do it's job!
dorr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dorr Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2012 at 5:54am
agrees with the dr and shameless had that problem on more than one tractor diesel and gas
This page was generated in 0.352 seconds.
