What year is my Model B?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: What year is my Model B?
    Posted: 18 Aug 2012 at 9:09pm
Trying to figure out if my Model B has the original motor.  Given the following numbers, can you please tell me a little bit about my tractor? It has electric start and PTO, but these may have been added later.  Also, what engine is this, the early one or the latter with higher HP?
Engine: (right side) AM2916-13, (upside down, on block) 11-25
Transmission: B65483
Tube: 12-20
Hopefully I provided all the information needed for an identification.  Thank you for your help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 9:21pm
Year Starting Serial Number
1937 1
1938 101
1939 11800
1940 33394
1941 49721
1942 56782
1943 6451
1944 65502
1945 70210
1946 72301
1947 73370
1948 80056
1949 92295
1950 102393
1951 114258
1952 118674
1953 122310
1954 124202
1955 124711
1956 126497
1957 127186
The Serial Number is located on top of transmission case, to the rear of the shift lever
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2012 at 9:23pm
so its a 1943. If you look at the vertical flange on left side of motor at the bell housing you  can get the motor number. You should have the CE motor which is 125 cubic inch and was a little stronger than the original BE motors prior to 1940.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2012 at 1:17pm
The serial number list posted is from ytmag and has an error on 1943 it should read 64501 since the numbers in 1943 were from 64501 to 65501.  So your serial number would say it is a 1943, however your casting number from the block says the engine is from 1941.  Many of these old tractors have had engine transplants though.  There should be a serial number stamped on your engine too that would be a better indication of its year of manufacture.  Here is a site that has the information you need:
http://people.clemson.edu/~wsmth/SNFind/esn_tsn1.htm
This page was generated in 0.158 seconds.
