190XT progress pic and ?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: 190XT progress pic and ?
    Posted: 16 Aug 2012 at 7:59pm
well i have been slowly getting my XT rearend back together.  It had been so hot and miserable I didnt really mind that i had been too busy to work on it.  Fixed the gear jumping problem with 3 gears and 2 shift collers.  Replaced every seal and o-ring in the back half.Here are a couple pics of the rear all done just without the bolts in top cover.  I have since mated the back half with the front and i am in the process of getting the PD valve ready to go back on.
Before i split it..the tractor wanted to creep with PD in neutral and trans in gear, you had to hold the brake.  Everything in the clutch pack checked out good, nothing broken and could spin freely.  i cleaned the PD valve in the parts washer and was blowing it off when i blew into the HYD IN port I got air and solvent out of both ports, HI and LOW.  the valve was in neutral and was spring centered. NOT ON TRACTOR IN MY HAND.
Does the valve allow a small amount of oil in both ports to lube the clutch?  or do i need to rebuild my valve?  They clutch pack turns(slips) easily on input shaft. so it would seem the valve is putting a little oil to both clutchpacks at once, even in neutral.
sorry the pics arnt very good  and the DATE IS WRONG
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 8:22pm
If I remember correctly you are suppose to get around 60 psi on high and low in neutral, which would mean some oil is designed to get past the valve.  And yes it is a wet clutch, so oil has to get to it ALL the time, even in neutral.  Don't quote me, or trust me on the psi number, but without the manual in front of me, I think that's right.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 9:10pm
well i have a manual, i guess i need to look harder. thanks for the input
so do they all creep in neutral then?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 9:23pm
yes they do   my xt and my dads 180 both do   i have herd its ok
        Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 10:04pm
Ours doesn't creep, but you can tell that there is friction in the clutch, the tractor will roll maybe an inch when letting out the foot clutch, but any resistance stops it.
Still in use:
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2012 at 10:34pm
Orange Blood, my old XT doesn't creep at all either,, Just like snapping the hand clutch into nutral on a WD...
  But all the others I have creep and drag.
  Just what makes the difference? mine was overhauled back in 1975/76 in Swea City Iowa.  Those guys did it right... Its slipping now under heavy loads but...30+ years isn't bad...and its still going. But needs OH and sure don't want it to creep or drag afterwards.
  So I wonder what make the difference, any body know the secret?
