Lining battery box?
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: Lining battery box?
    Posted: 09 Aug 2012 at 9:46am
Is anyone lining their battery boxes in case the battery leaks? I have had problems with both of mine and have messed up my paint. Any ideas? Thanks Mike
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 9:52am
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:03am
Years back Honda cars came out with a little plastic Battery tray that goes under the Battery. As time progressed, some of the other mfrs have followed suit. Probably could find one of those trays to fit in the AC Battery box. This way anything expelled from the Battery winds up in the plastic tray and not running down the side of your nice paint job.. Just a thought.. Might even be able to find a Tupperware container that you could cut down that your Battery would fit in. Viola! Self contained Battery box, in the Battery box! No muss, no fuss, no mess....  Thumbs Up
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:23am
Any thing you can line with will just be a cover up. Acid will get behind it and eat it out anyway. The reason batteries leak is because your tractor chargeing system leaves much to be desired. Their was someone making stainless steel battery boxes a while back I don't rember who. I put Optima's in they don't leak. and last forever.  I'm going to need to replace one before winter but it's been in the tractor since 1992.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:33am
Don't over fill the battery and it won't boil over.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:43am
Steve Jelf
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 10:53am
I have a plastic Battery Box meant for a Boat on my D-12.
Gary
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 11:06am
I guess someone could be profitable if they could manufacsure orange plasic battery boxes that resemble the original?
I have one of the stainless steel boxes for a WC that I never used.  For sale if anyone needs one.  PM me!
Edited by john(MI) - 09 Aug 2012 at 11:08am
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 11:13am
I know Steve still has them for sale, not sure what he's wanting for them though.
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 3:59pm
I understand that batteries shouldn't overflow but one was a bad battery that came with the tractor, the second was a good battery that I made a mistake with! That being said I am not by my tractors for a couple of weeks at a time and was looking for something that if it happened I would have some protection until I fixed the problem. I don't think I am the only one that has had this problem. Thanks for the suggestions. Mike
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 4:02pm
I SPRAY THE INSIDE OF THE BOX AND LID WITH TRUCK BED LINER. WORKS WELL AND YOU DONT SEE IT ANYWAY.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 4:19pm
i use optima batteries i have one in my boat that is a 2000
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 5:26pm
Use a dry cell. No corrosion or leaking. Cost more, but worth it.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 5:32pm
I put a sealed Deka brand 12v in the C but my WD-45 is 6v and I don't know if they would make a sealed battery for it. But I already have a 6v Deka to put in it.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 11:55pm
second ctbowles, i also sprayed on bed liner when I built my box, should last years
PlayGun View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PlayGun Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 11:56pm
I use Line X stuff from Oreilly's or Tractor Supply.
Hopefully Future AC Man! Ride With Jesus my friends!     Lonas
