e compresion
colroy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Topic: e compresion
    Posted: 08 Aug 2012 at 3:52pm
what is the average compresion of a e gleaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 4:48pm
What do you have????
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 5:46pm
49 wc with a e gleaner engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 5:48pm
thats all i can tell you i dont know which series
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 7:28pm
WHAT ARE YOUR COMPRESSION NUMBERS?
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 9:51pm
im lost
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 9:53pm
i just wonder how many psi i should have on a e gleaner engine if i put a compresion tester on the spark plug whats bad,good,excelent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 9:56pm
Excellent is when they are all the same.....150-150-150-150......you can't change what it is, they just need to be the same or very close to the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote colroy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 10:03pm
thats all i wanted to know was 150 i didnt know if i need to overhaul or not  now i know im ok i saw on the forum where someone put a 45 crank in a wc engine and they had 210 psi sounds like alot.
