rebuild question |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25347 |
Topic: rebuild questionPosted: 06 Aug 2012 at 8:35pm |
anybody know the best way to degree a cam gear? LOL sorry, I can't help meself
seriously, the sealing surface where the sleeve O rings will live has some serious pitting, looks like the lower ring will be OK, but, measuring down from sleeve seat it looks like the top rings are going to be either just below or right on some pits
anybody see this before and how did you fix it? sealer? epoxy? liquid metal? Edited by LouSWPA - 06 Aug 2012 at 8:36pm |
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 06 Aug 2012 at 10:11pm |
I'll stay away from the first question cause "I have trouble finding TDC"
![]() If an epoxy is the answer, I would think a little work with a brazing tip might cook any residual oil out of the iron so it would stick good. |
LouSWPA
Posted: 06 Aug 2012 at 10:42pm |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8702 |
Posted: 06 Aug 2012 at 11:34pm |
Right or wrong,I JB welded some spots on my Cat truck engine last time around. 480000 some miles ago
JoeB
Joined: 12 Sep 2009 Location: S.W. Jersey Points: 64 |
Posted: 07 Aug 2012 at 5:23am |
I second JDWeld. Good luck.
MACK
Posted: 07 Aug 2012 at 6:51am |
Cut another oring grove between the 2 and put in the 3rd oring or machine the block at bottom and sleeve the area. MACK
MACK
Posted: 07 Aug 2012 at 7:09am |
JB weld will not stay in. MACK
wi50
Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
Thanks(1)
Posted: 07 Aug 2012 at 7:21am |
For the cost of doing this machine work why not get another block? Your old block has good value as some tractor puller will bore it larger anyway. I've got good blocks on the shelf and would trade you but shipping would make it no value.
To do it right it really needs to be bored and sleved. But I have used a product called RocBlok from Competition Products in Oshkosh Wi. It's a fiber based block filler and works great as a sealer vs the grout based fillers. Assembling the liners as normal and an inch or two of this would seal as long as you have the block clean. |
