C distributor
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Topic: C distributor
    Posted: 06 Aug 2012 at 9:00am
what distributor assy's will work on my '49 C ?
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 9:07am
Any one of these three will work. The one on the left is an after market that fits the AC as well as Farmall. The one in the center is from a D-15 or all down to the D-10. The one on the right is from a CA. The D-15 has an opening to the back with a slotted shaft for a tac. Both that one and the CA would need to change governor shaft and weights. The after marke just bolts on in place of a magneto with no changes to the governor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 9:13am
are all of the little farmalls the same and what about governor changes? As soon as the engine is free it will get a distributor, I don't want to pass over one in the mean time. Is the dist. itself the same for WD ?
thanks
2014 HD Tri Glide
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 9:13am
After my magneto destroyed itself, I put a distributor ignition, with electronic "points" and a high energy coil on my '48 C. I think I got it from Steve at B&B in New Jersey. Starts and runs great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 9:16am
I will go straight to electronic, after 4 years of quick/easy starts in the '45, I'm sold
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2012 at 1:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 6:42am
As Ed mentioned, we have a complete rebuilt Mag to Distributor kit as in his picture, or if you're just looking for a Distributor, we have em' on the shelf exchange or outright rebuilt and ready to install. E.I. is optional, and I can install it for you no charge. Stick with a Delco unit for the AC machines. Delco Distributor numbers  1111411, 1111435, & 1111475, will work on your C model....
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2012 at 9:04am
There are 2 different distributors with different drives that work on the B, C, CA, and D series. (one that uses the magneto drive and one that has a seperate drive). If you are replacing a magneto you can use the distributor that Dick L shows as #1.... or pull the front cover and drive and replace the magneto drive with the distributor drive/weight assy and use one of the other two styles of distributors he shows.
I gave my neighbor a magneto drive distributor from an Allis C and he replaced the magneto on his WC with it and has been driving it for 5 years now.
