Clutch Problem on D 17?
holmesd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote holmesd Quote  Post ReplyReply Direct Link To This Post Topic: Clutch Problem on D 17?
    Posted: 05 Aug 2012 at 4:41pm
I have a 1958 D 17, it has been running fine.  I hooked up my brush hog to the PTO and was cutting away when it decided to slow down and not move both the tractor and the PTO.  Here is what I have, a tractor that when in gear will not move and the PTO will not spin.  When I take it out of gear and put it in netural and let the clutch out the PTO will spin, no problem.  When I leave it out of gear and move the hand clutch to high or low the PTO will slow down some but continue to spin.  Any suggestions on what I have going on?
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 6:17pm
Sound like the clutch is slipping.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 6:46pm
what do you mean when you say?
   B:-)    Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote holmesd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 7:08pm
The gear box is in neutral and my high /low lever is also in neutral.  I then move the high/low lever into either high or low but leave the gear box in neutral.
Post Options Post Options   Thanks (0) Thanks(0)   Quote holmesd Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 7:09pm
Any idea on the cost to have the clutch replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 9:19pm
$250 to $500 for parts depending on what you need and where you buy them. Four to six hrs labor @ whatever the hourly rate is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 9:25pm
If it's slippin that bad, you might need a different flywheel. My 45 slipped on me while mowing with a Brady flail copper a few times and the flywheel had heat cracks all the way thru and 3 or 4 inches out from the middle.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Aug 2012 at 9:41pm
Might try to adjust the clutch rod linkage. It may be worn enough to be holding the clutch down.
Yea, I can fix that.....
