2 way plows on a B
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: 2 way plows on a B
    Posted: 04 Aug 2012 at 9:50am
I picked up a pair of plows this morning to put on my steel wheel B. I'm not sure if I have all the parts I need so if anyone has some pics of them mounted that would be great. Thanks
Not sure what happened on my pic?
Edited by MNLonnie - 04 Aug 2012 at 9:50am
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 10:20am
I dumped out my garbage can full of parts that came with the plows but I don't think there is much for plow parts in there. Anything look familiar?
Looks like a swinging draw bar, hydraulic line, wooden pitman arm and other stuff.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 10:31am
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 1:32pm
  Gonna try to add several pictures of the plows on my B...
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 1:34pm
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 1:41pm
Quick look , it appears that you are missing the front plow drawbar and the brackets that attach it to the bull gear housing. Also missing one hydraulic cylinder and the left-right hydraulic switch. Good luck.Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 2:15pm
The pics help a lot, guess I need to find more parts.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 6:56pm
  did not see the  two way valve
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 8:16pm
Lonnie, nice find.  Must be a good day for plows, as just this morning I picked up the left hand plow I've been searching for quite a while.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2012 at 8:44pm
Ok, I scrounged around out back and found the front plow bar and the final drive brackets. I only have one of the clamps to hook the plow to the bar but I could make one of those if I had to. Problem is my B is missing the rock shaft and it's an early hand brake B with the low seat brackets so that is the most needed part at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 6:33pm
Well I finally found the parts I needed and got them all mounted up. I don't have the plumbing hooked up yet but I have cylinders.  For now there is a piece of steel in place of the cylinders to hold them up, that'll have to do for the local show this weekend. Had to put the engine weights on to help keep the front end on the ground. Thanks for all the pics and info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 7:52pm
Looks great Lonnie.  Makes me want to put the rear steel and 2 way plows on my C... but I really don't have plans to do it anytime soon, I've just gathered the pieces of the puzzle for now.
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 7:59pm
Murph, load your fax. Operator manual coming in the AM. I'll work up the parts manual if you need it also. Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 8:05pm
Mike, thanks so much for the help.  The fax will be ready.  It was mainly the OAN article I was wanting, as I just confirmed I have the "Operating Instructions and Repair Parts Illustrations" manual.  Thanks again.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2012 at 8:14pm
Neat looking unusual Steel Wheeled B.
You have a treasure there.  If you can get the rams, hoses, and valve you will have an outstanding rig.
Thanks for taking such good care of my favorite.
Good Luck!
Bill Long
