Wanted 170 gas engine govenor |
Post Reply ![]() |
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10794 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Aug 2012 at 9:04pm |
Looking for a governor for a 170 gas engine . Any help appreciated. Tracy Martin
d17brown ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: farley iowa Points: 1723 |
i have one for sale
Does the housing on a combine engine and the one on a 170 interchange? I was told they are differant.Is all that is needed is governor weights or entire unit? Thanks Tracy Martin
Edited by Tracy Martin TN - 02 Aug 2012 at 10:23pm |
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
Just the weights and spring are different, I believe.
Matt, just trying to confirm. I don't have a parts manual on combine engine or I would compare part numbers. Thanks for info. Tracy Martin
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8630 |
www.agcopartsbooks.com "guest"...... diff #'s for both spring and weights.The tractor spring has a slug inside to close throttle.I doubt the combine one does because it is adjusted by a screw to set high idle and the carb shaft is pulled on to close it.
the timing covers are same #.....the front cover is diff Edited by SteveM C/IL - 02 Aug 2012 at 11:20pm |
cotncrzy ![]() Orange Level ![]() Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
I am pretty sure you can change the weights off combine engine to the 170 weights.
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
Post Reply ![]() |
