B 5- bolt hub swap
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Topic: B 5- bolt hub swap
    Posted: 02 Aug 2012 at 8:30am
Thanks to Bill Long for his input!
I'm wondering if anyone has switched out the splined axles on an older B for then newfangled 5- bolt? Can they be directly replaced or do you need to change out the bull gears and/or entire final drives?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 4:15pm
I have a '39 B with a splined adapter to 5 bolt on one side. It has a flatter center than a C dished center. I hope to find another someday. On the front it has one riveted wheel/hub and on the other it looks like they removed the rivets and threaded the holes for small lug bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 4:40pm
KEn, the axles are interchangable if you can find one. Same bull gear, same installation. Different hub.
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 7:11pm
Will a CA hub switch out with a B or C?
MikeinLcoMo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MikeinLcoMo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2012 at 7:13pm
I've got a set of 5 bolt finals off a '48 B that need to go. Mike.  Cheap!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 11:02am
Thanks Steve!
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2012 at 12:45pm
I've got a pair of spline to 5 bolt adapters in perfect shape that I may sell?
Andrew
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
