Freeze Plugs
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: Freeze Plugs
    Posted: 31 Jul 2012 at 2:12pm
How do you remove and replace a freeze plug in a AC model C. Is it just a friction fit? Do you need a sealer?. Any tips on how best to do it?
ThanksWink
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 2:47pm
My best suggestion is to go to You-Tube and search for clips on freeze plug replacement.  That's what I did.  I don't think any sealer is needed but I did put a very small amount of RTV on mine before inserting it just to be safe.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 3:43pm
unsure of which cups are used be the convex disc or the full cup , the disc fits into a machined bore that had a shoulder it sets against then is hit wit ha ball peen in center to expand it.
 The cup is enough oversize it is a press fit into machines bore. In either case a little permatex #2 does not hurt, just don't go overboard.
 to remove the cup type a punch is used on one side (inside of cup / not on edge ) to turn the cup and then pull out with a pliers or vice grip . on other type drilling and using a slide hammer works
Edited by Coke-in-MN - 31 Jul 2012 at 3:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2012 at 7:31pm
Thanks, I got it out>
TedTongue
