AC 185 and 3rd gear
GHAcres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHAcres Quote  Post ReplyReply Direct Link To This Post Topic: AC 185 and 3rd gear
    Posted: 30 Jul 2012 at 10:34am
So I had to replace my shift lever this weekend and had a chance to inspect the gears.  One of the gears is chewed up pretty bad (third) and the reverse gear is also beaten up.
So my question is....What does it take to change these gears out.
I assume that the tractor has to be split but then what?
All previous comments said this was the best way to fix the gear jumping.
Is this something that can be done on the farm or does it have to go to a shop.
I am willing to do the rear down but transmissions I am not to sure about.
Any thoughts.
Thanks,  GHAcres
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 12:01pm
I believe u start from the back and everything comes out and off till u get to the tranny gears
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2012 at 12:48pm
As stated, support tractor and start from rear. It's really not a complicated job assuming you have ability. Get that rear housing off, put it on a work platform that is at right height and pull it apart. Don't get crazy a nd start replacing all the bearings, etc unless they need it. Shift collars are most likely shot, replace them, seals, do brakes while it's apart. You can save some good $$$ doing it yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 6:20am
The gears and collars are avaliable thru A+I , and on Ebay alot cheaper!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHAcres Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 8:37am
Thanks for all the suggestions.  Is there something better than the IT manual that would have more information.
Just as you said you start at the back after you have the tractor split.  But it would be helpful with a few more pictures/ instructions.
Also, as stated on many posts, a contributing factor to the gear destruction is that the shifting forks were possibly not aligned initially.  The forks look good but have some wear.  should they be adjusted/modified after the new gear set is in place.
Thanks again for all the replies
GHAcres
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 8:52am
I would recommend getting the actual service manual through an AGCO Dealer. We had an IT manual for our D-19 and it wasn't that great. Just my opinion though.
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHAcres Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 10:51am
Now that I have seen the parts breakdown on AGCO.  The gear that is all beaten up is the Main Shaft Sliding gear which is where the shifting fork sits and the reverse gear where the reverse shifting fork sits.
Is the repair the same procedure, is there more gear damage on the counter shaft that I can't see (since this pops out of third gear).
Thanks,  GHAcres
nsula_country View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nsula_country Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 10:55am
I found reproductions of the 180 Operator, Parts, and Service manuals on EBAY, loose leaf 3 hole punched in binders for like $60-$70 for the set of 3.
CT
Edited by nsula_country - 01 Aug 2012 at 1:34pm
2014 LS P7010C, 1962 Farmall 504 Diesel (1st tractor) w/ 2008 Koyker 220 FEL, 1968 Allis Chalmers 180 Diesel, Komatsu PC38UU-2 Excavator, Various attachments for all!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 2:01pm
TBran had good advise on this , the last snap ring has to fit very tight so there is no play in the gears on the shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote GHAcres Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 2:22pm
Doug G, can you give me more info about TBran's comments.  I searched his posts and couldn't find anything about this situation.  Do you have a link.
Thanks to nsula_country. I found a service manual there on ebay for $26.  Thought I had all the manuals that were available already.
Thanks
GHAcres
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2012 at 2:37pm
Ill look for it, its been a couple years, i had it saved , it was a good how too, very informative
