B Model - sputtering under load
Bill Myers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Myers Quote  Post ReplyReply Direct Link To This Post Topic: B Model - sputtering under load
    Posted: 22 Jul 2012 at 3:38pm
Good afternoon -
I have a B Model that started sputtering when under the load of the finish mower. There was some dirt in the gas bowl which I cleaned  and changed the fuel filter. I cut for about an hour this afternoon and it started sputtering again. Ran fine back to the barn, but each time I tried to engage the mower, it sputtered and nearly cut out. The gas bowl is still clean and the filter looks clean. Any ideas?
Thanks,
Bill
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 4:04pm
Crud in the gas tank. Sounds like the engine is running out of fuel under load. Take the sediment bowl assembly out and clean the tank, check the line and double check the main jet in the carb allong with the other straight foreward things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Myers Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 4:09pm
Will do. Thanks!
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 4:31pm
As hot as it has been i SPUTTER under a load to.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 4:45pm
If you have a mag on your tractor, you may have a bad coil. I had similar problem and and found that the coil was bad on mine. Unhappy
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 8:38pm
I have a model B that does this also. Mine was  fuel line related.  If I was a gambling man, I'm sure yours is also.  Going orange is going great!
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 8:56pm
Get your fuel system cleaned up and then listen to her purrrrr !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 9:07pm
If it starts to sputter, pull the choke out some and see what it does.This is a pretty simple test to see if it is a fuel problem or spark problem. If choking helps it, start checking for a fuel restriction everywhere from the tank to the carb. If choking it has no effect, start with a complete tune up of the ignition system.
Edited by CTuckerNWIL - 22 Jul 2012 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 9:08pm
Bill, first off welcome to the Forum. What has been posted is good advice. Also you might want to invest in a fresh set of Autolite 295 plugs if yours have a bit of time on them. BTW you are too close to "Hotlanta" for this old country boy. Jackson County is getting a little crowded for me too. Got two B's - one waiting on brake installation; one parts donor that I may get running for a spare.
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2012 at 10:01pm
my c recently started doing something like that. it turned out ot be a loose rocker arm lash adjuster. it only seemed smooth with no load, i soon realized i couldn't get full speed out of the motor at no load. yours probably not that, more than likely fuel, just some food for thought
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 6:27am
As "Tuck" mentioned, the choke trick works almost everytime if its a fuel delivery problem. When you pull the choke a little bit you cut the air to the engine and fatten the fuel mix. If the engine responds, its a fuel delivery or dirt or debris in the load side of the carburetor. Carb needs a roto-rooter....
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 8:59am
Look at the screen in the fuel line inlet adapter. I've seen it choke and engine to the point it would only run for a few seconds every 10 minutes.
Gerald J.
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2012 at 9:55am
My "CA" started doing that a while ago. I replaced the governor return spring and it ran fine afterward. Maybe try that.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Myers Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:17pm
thanks for the good advice. flushed the gas tank, lines, etc. runs like it is 1952! great tractor. i grew up with farmalls and JDs, never had anything "orange" but sure will keep this one!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Myers Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2012 at 7:21pm
Hey Hubert - yep a little to close to the big city but not for much longer. Looks like your a ff or medic...thanks for your service!
This page was generated in 0.049 seconds.
