Replace seal on AC 185 RAM cylinder |
Post Reply ![]() |
briarpatch ![]() Bronze Level ![]() Joined: 02 Dec 2011 Location: Vichy, MO Points: 15 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Jul 2012 at 12:08pm |
Does anyone know how to replace the large (3") seal on the RAM hydraulic cylinder that raises the left link? This cylinder has only a single fluid input hose and uses the weight of the tool to lower the 3-point hitch. Any special tools or tactics needed?
cotncrzy ![]() Orange Level ![]() Joined: 07 Oct 2009 Location: TENNESSEE Points: 599 |
No special tools needed, remove from tractor, remove hose fitting, slide snapring to groved space on the end of ram through fitting hole, pull out ram...
C, WD45,WD puller, 185, 200, 7060 Red Belly, 7060 Black Belly,8010, and a R52 Gleaner, AND PROUD OF THEM!
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8635 |
That snap ring can cause some frustration but you can do it. Patience is a virtue.
Post Reply ![]() |
