Trying to find a part for my c
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Trying to find a part for my c
    Posted: 21 Jul 2012 at 9:10am
I was told once a while back but I am wanting to put live hydraulics on my c and there was an international pump/part that bolts to where the distributer does. Does anyone know what this part is and how to find one. What tractors did they come on?
Can't fix stupid
EdK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EdK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 10:36am
Not sure what your talking about. The hydraulic pump on a factory built C is located on the transmission and I believe that the pump you are describing, if available, was not standard factory supplied.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 10:54am
AJ
I believe some of the mid series D-10 and D-12's  had the hydraulic pump set-up that you describe, mounted at the distributor.
Gary
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 10:59am
This is from an old post:
I know that all you guys are diehard orange but I love all old tractors and the older the better. one thing that I have found out is that some parts will interchange from other brands. Did you know that you can replace the mag on a wc or wd with a distributer from a H or M farmall. I have 2 WD's that get about 750 hours a year on them for 3 years with IH dist. if you want live hydralics, you can put hydralic pump from a 300 or 400 series farmall on but you will also have to use a super m or h upright dist to clear the oil filter. I have a styled wc with a dual loader a wd wide front, the generator and power steering of a 444 Massy Harris, a 350 IH hyd. pump and super m dist., and foot brakes from a wd . Also, i just seen a post that spoke of round spoke rear wheels. these wheels were made by F&H and are the same wheels that were put on f-20 farmalls and GP john deeres. in fact, i have an f-20 i bought with round spokes and an unstyled WC i bought with f-20 rear steel. Hope you can use some of this info to keep your ac's working!
Edited by GregLawlerMinn - 21 Jul 2012 at 11:01am
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 12:27pm
Yes that is in the ball park of what I was told. I just don't know which farmall/internationals are the ones that will fit my allis c set up.
Can't fix stupid
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 3:54pm
Greg, If this is an old post of yours, do you have any pics of the hydraulic setup on your WC? I asked about a WC hydraulic setup in an earlier post and would like to see one. Thanks!
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
rtwfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rtwfarm Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 5:14pm
i have a wc with hyd. pump mount of front pulley
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2012 at 6:24pm
   m&w made a pump like you want ffffor your c   inthe 50's  they still show up at auctions
   they are shown in our m&w books  they bring hi dollars   1-574-342-4545
