wd45 oil pressure
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 oil pressure
    Posted: 20 Jul 2012 at 10:11am
Hey guys just another quesgion about my wd when I first got it there was alot of sludge built up under the valve cover and what not the oil was very dark and hadnt been changed in a long time, after changing the oil a few times it was now clean. But my oil pressure was still pretty low, here the thing if I have it at mid to high idle the oil pressure stays up if I idle down or go down or up a hill it drops I don't know what is wrong. I was wondering if I took off the oil pan and cleaned out the screen and all the sludge that is down there will it help me at all? any suggestions please! Thanks justins!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 12:34pm
Please someone help?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 12:35pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 12:43pm
Low oil pressure at low engine speeds can come from many causes, and there's no guarantee that only one is contributing.
The sludge could have locked the pressure regulator piston in place so it doesn't close the bypass at low engine speed.
The oil pump pickup screen could be mostly clogged with sludge and grunge.
The rod bearings could have lots of clearance and so need a larger oil flow than the pump can supply.
The crank shaft bearings could be worn...
The cam shaft bearings could be worn....
The pump could be worn.
The oil filter could not have enough restriction to hold up the oil pressure. In the past few years some makers have tried pleated paper filters in place of the original cotton waste filters and those new filters kill oil pressure.
The tube that leads into the oil filter could be missing and that makes pressure not hold up as well.
The oil pressure gauge may be giving misleading readings from rust of gauge parts.
That enough starts?
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 1:08pm
Thank you very much!
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 1:15pm
I think Gerald has a complete list of possibilities there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 5:03pm
If you truly see a change in oil pressure when going uphill/downhill versus flatland, you better be pulling the pan for a looksee.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 5:31pm
I really do no joke!
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 9:28pm
what do you mean when you say "low oil presure"?
At idle on a WD 5 lbs is good. This is a low presure system, with max being about 18-20 lbs. Do you have the original gauge or one with presure markings? A marked gauge should have a max of 30 lbs to get an accurate reading on the low end. The factory gauge max is around the R-M in normal, at running speed, and as low a N at idle is normal. Bob
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2012 at 11:56pm
Then I guess it's fine thanks bob. I'm gonna take off the oil pan tomorrow and clean it anyway
