WD45 Power Unit - What would you
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Power Unit - What would you
    Posted: 18 Jul 2012 at 4:25pm
put a spare wd45 power unit engine in.  I have an spare WD 45 Power Unit.
I have enough AC tractors, am thinking about putting the spare power unit in a Tracto Motive Loader or perhaps looking for an Allis Grader that needs a good motor.
Do you guys have any other good ideas on how to use the spare WD45 Power Unit.
Appreciate your input.  Thank Guys...Orangeman
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 4:54pm
 Figure out how to make it work in a CA and go pullin' !
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 5:34pm
i vote for the grader.  lot more tractors around than industrial equip.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 5:51pm
Hey Cal and Gary:  I guess I could put an adapter together for the CA housing and bolt up and pull like a scalded dog.  I really like the AC Construction Machinery always thought it was well made American Iron.  I am leaning toward put the 45 power unit engine in a good piece of construction machinery.  Open to all options and thoughts at this point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 6:14pm
 I  wasn't serious about the ca swap.  I'll turn off the sarcasm... save it for you know who,   If its a power unit in an enclosure I would restore it,  GBACFAN has some really nice restored BE  power units,  a  grader or loader would also be a great candidate
Larry in Ill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 6:27pm
One WD45 to CA adaptor.  And yes, if I had a 45 engine, I'd do it again!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 6:54pm
Ok Guys: the power unit is on a steel  C Channel skid, it is complete with the clutch, radiator and all the sheet metal.  No side plates :(.
Larry - Nice looking adapters right there!  Would love to see the 45 engine in a CA. The 45 engine was some fine American Muscle built by the one and only Harvey engine plant. Geepers I wish AC was still around.  Guess I am just a sentimental coot livin back in the Glory Industrial days of the American build up.
Anyone else wish AC was still with us???
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 6:58pm
Put an axle under the skid, a hitch on the front, paint it all up and have a nice show piece, if your into that sort of thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 8:36pm
I've got the under carriage and differential of an OC46 Oliver here just screaming for an Allis engine and sheet metalSmile Thumbs Up Clap
If I had a WD45 engine in it, it would be mean on a bush hog out in the back brush.
Edited by CTuckerNWIL - 18 Jul 2012 at 8:37pm
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 11:20pm
Here is a pic of my power unit on my 1945 Oliver Cletrac.  Now an ALLIS-CLETRAC...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 6:17am
I would probably make a gen set out of it. Been wanting one for a long time and would put my mind at ease having backup elect.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 7:20am
I'm with KGood.  Put the gen set on it and on a cart so it can be moved easy.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
This page was generated in 0.058 seconds.
