Wd45 wheel weights
Allis-chalmers wd45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 wheel weights
    Posted: 18 Jul 2012 at 10:21am
Is it worth me picking up a set of rear wheel weights for my wd45? Fairy cheap will they help with wheel spin at all?
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 11:32am
depends on what you are doin to get wheel slip??  might take two or three sets .
      Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 1:37pm
Just discing I just got a set for 50
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 1:53pm
I,d put them on and I agree 2 or 3 sets would be better. Are you able to use the traction booster?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 4:16pm
I'm not sure if it's working I don't think it is how would I fix it?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 4:39pm
It depend what kind of disk do you have. you'll need a snapcoupler disk for the traction booster to provide any assistance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 10:38pm
Okay I'm jut using an old jd pull type disk
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2012 at 11:28pm
fluid in your tires will add about 750-900 lbs depending on size
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis-chalmers wd45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2012 at 7:39am
Okay I'll see what happens. What f&h weights. We're meant for a wd?
