3-point conversion
Freewheelin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freewheelin Quote  Post ReplyReply Direct Link To This Post Topic: 3-point conversion
    Posted: 16 Jul 2012 at 8:39pm
I'm considering a 3-point conversion for my WD and want a well made unit.  I'd appreciate if you'd share your experiences and thoughts regarding the best on the market.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 8:56pm
I've got 2 A-C units here,the ones that allow PTO to be used.Must say they are well designed and built tough.Don't know if they're 'specific' for my D-14 though.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 10:11pm
Here is the one I bought from Tony's. Very nice setup...easily removed so you can use snap coupler implements. Plus you can drop the drawbar and 3 point still stay on tractor to use.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 12:23am
The one shown above is my favorite for the wd and wd45.  It's what I had on mine and they really work well.  We sell it as the "newstyle" on our site below.
JimD
Edited by JimD - 17 Jul 2012 at 12:24am
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 10:51am
I must be haunted by Mr. Ferguson--
I haven't converted anything to 3 point yet, but I always want to incorporate draft control (traction booster) when figuring out how I might do it. When browsing at AC kits, I always gravitate toward the option that will aid plowing for some reason.  Maybe I'm thinking if the tractor already has the feature from the factory, you should use it.  But then again, how many people use the tractor primarily for tillage anymore?
-karl f
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 4:39pm
-karl f
This hitch doesn't "convert" your tractor to 3pt only. I still use snap coupler equipment...just drop your drawbar like normal and hook up to the snap coupler implement.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2012 at 7:42pm
Some of the 3-point conversion kits actually present draft load through the snap-coupler hook, hence, the traction-booster system still functions... if you so desire.  The downside, is that if you'd like to use SC implements, you'll hafta yank at least SOME of the 3-point conversion stuff.
I built my D17 Series I's 3-point kit, and one of the concerns I had about mine, was that draft load doesn't go through the SC hook... it bears upon the bolts passing up into the bottom of the transaxle.  They're stout bolts, and I used proper selection of materials and fitment to assure that they won't be easily broken by shear strain, but it doesn't alleviate the fact that draft loads are NOT going to where the 'factory' engineering had it applied.  Haven't broken anything yet, and hope I never will... but it certainly has capacity to lift, and so far, has not shown an inkling of failure suggestion against some substantial abuse.
