little allis impliment help
tmiller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tmiller Quote  Post ReplyReply Direct Link To This Post Topic: little allis impliment help
    Posted: 16 Jul 2012 at 1:54pm
BIIIIGGGG farm auction next week, guy started farming in 50's never sold anything!
Looks like he started with allis then moved to IH
He has allis plows, post auger, planter,cultivators sub soiler, blade, etc
My question, some of this stuff hooks to the rear and its all allis brand so how did it hook up? is it close to 3pt hitch that i could put it on my 3pt or could it be done easily by changing pins or is the allis set up completely different?
thanks
taylor
bdallman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 2:55pm
Allis Chalmers Had the Snap Coupler system. Basically had two lift arms that lifted the implement. The implement  would also be held in by an eye hole that actually attaches to a spring loaded hook directly under the driver.  The operator would back up to the implement until they heard the "snap" of the spring loaded hook. You would attach the lift arms and up you go.
With that being said hooking a snap coupler implement to a 3 point tractor would really take some reworking but i guess anything could be done.
1954 CA, 1952 WD with Freeman Loader,1955 WD45, 1963 D19 Gas, 1984 620H, 1980’s AC Forklift, 66 All Crop Harvester, White Top Roto Baler, Misc S.C. Equip and AC Collectibles.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 6:15pm
Buy any of the equipment you want or think you can use and then find a WD or a WD$% and use the stuffThumbs Up
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 6:24pm
some snap coupler equipment also had a 3pt setup that went on as well . you took the long rod that the arms went on   off and the 3pt setup went in its place i have only seen this on a set of plows .
               Shawn
190XT,D17and 7045
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 6:25pm
Allis plows could be assembled (with additional parts) as snap coupler, three point, or pull behind using the same frame and ground contacting parts. The parts book makes it look like one ordered the frame and then the hitch and then the plow bottoms off of separate lists.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2012 at 6:28pm
The Oxnard blade could be changed from SC to 3 pt. or visa versa.You would still need the right parts to change any of these over from SC to 3pt.
Edited by CTuckerNWIL - 16 Jul 2012 at 6:29pm
