problems with wd
khioc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote khioc Quote  Post ReplyReply Direct Link To This Post Topic: problems with wd
    Posted: 15 Jul 2012 at 4:22pm
need help with wd, has popping sound out of exhaust when under under load. lacks power. i have re gaped points but no help changed plug wires. problem started when i smoothed off points.
Lars(wisc) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wisc) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 4:33pm
my first guess would be to replace the points
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 5:20pm
I would say buy a new set of points. You can't file points today like you used to cause the contact surface is paper thin. Then go back and double check your plug wire orientation with the firing order.
jjwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jjwo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 5:25pm
Try another condensor, if I remember right.
