D21 front wheels ,8 hole to 6
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: D21 front wheels ,8 hole to 6
    Posted: 15 Jul 2012 at 5:59am
I thought this was a topic while back but cant find anything on it, im wanting to put 6 hole wheels on my 21 , are an XT bearings and hubs the same? ? Whats a good swap? ?
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 7:38am
I know the 6 lug is original for the series 1 D 21 tractor. I think you can use the XT, but I am not sure.
Happy hunting!
Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 8:26am
Do you know when they changed from 6-8 (serial #) as I have a brocure and some other lit that shows the series 1s with both and I have serial # 1300 and it looks to has the 8 hole and one orig rim even with the galv rim and the white center, thanks guys, Dustin
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 8:48am
I dont think you can use the XT set up. Bearings are different i think. Otherwise the six bolt hubs wouldnt be so hard to find. But i could be wrong.
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 10:24am
our serial #1251 63' had the 8 bolt and our 64' has 8 bolt. I think it must have been an option and most took the 8 bolt. If the 6 bolt uses the same spindle (never seen one up close) then 190 stuff won't fit.  Doyle
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2012 at 1:52pm
Lot of times same hubs use different brg race dia to fit diff spindles.
