Radiator on a WD45
bdallman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Topic: Radiator on a WD45
    Posted: 13 Jul 2012 at 12:07pm
Going to be putting in a new Radiator on my wd45 this weekend. It looks to be pretty simple but it there any tips or tricks that i may need to know to help with the process?
Thanks guys!
Brett
1954 CA, 1952 WD with Freeman Loader,1955 WD45, 1963 D19 Gas, 1984 620H, 1980’s AC Forklift, 66 All Crop Harvester, White Top Roto Baler, Misc S.C. Equip and AC Collectibles.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2012 at 12:10pm
I'd replace the top and bottom hoses,clamps and fan belt too.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2012 at 2:08pm
If you have a 3/8" ratchet with a long extension and a 3/4" socket, it's pretty easy.  Put the socket on the bolt, then put the ratchet extension through the hole in the bottom lip of the frame rail.  Does that make sense?  That makes it easy to use a ratchet to get the 2 radiator bolts out.  If you have a narrow front, you may need to turn the wheels a bit to get some clearance for the ratchet, but it works slick.  Other than that, I'll second that Don said.
AaronSEIA
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2012 at 7:18pm
Make sure tha tyou have the correct radiator with the small overflow tube that points toward the back of the tractor and routes down the right side. A&I is selling WD45 radiators with overflows pointing out the right side that require cutting the hood.
Yes... I now have an ugly notch cut into top of my hood...
Post Options Post Options   Thanks (0) Thanks(0)   Quote bdallman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2012 at 9:37am
Thanks guys for the input. Radiator is now swapped out and we are leak free
Took a couple hours including cleaning the 1" of gunk off the front of the motor caused from 30 years of the valve cover leaking. Don't worry gasket has been replaced also.
