CA coil shank field cultivator-pin hitch
Randy H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy H Quote  Post ReplyReply Direct Link To This Post Topic: CA coil shank field cultivator-pin hitch
    Posted: 09 Jul 2012 at 5:16pm
I thought I had found a snap coupler field cultivator yesterday.
But after talking to Brenda today at Sandy Lake I found out that I am looking at a older model pin hitch.
My CA is a 1955 with snap coupler.
I have a old snap coupler plow that I can get the eyelet off of and maybe the latch arms if needed.
My question for you guys is can I make the pin hitch unit work on a snap coupler tractor
Has any one ever converted pin hitch equipment to use on a snap coupler?
Any advice or ideals would be appreciated.
Thanks. Randy.
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2012 at 5:32pm
I did it on a planter and a rear blade - bolt holes matched - should work for you. The lift latches may be different tho. Early lifts bolted to lift arms while later used the latch release type. Still I think you could make it work by swapping parts.
Edited by Larry Miller - 09 Jul 2012 at 5:35pm
I used to be young and stupid, now I am not young anymore.
