F2 drive shaft |
wheatbreeder
Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 581 |
Topic: F2 drive shaftPosted: 08 Jul 2012 at 4:20pm |
How much work is it to replace the shaft from the transmission the differential on the left side of the combine. The splines on the shaft and sleeve are rounded off.
Morley
Farm stuff 8050,6690,175,F2,5050,WD
soybreedingboy77
Posted: 09 Jul 2012 at 6:10am |
My uncle's dealership took 2 bad uni-mule transmissions and made one good transmission for ADM last winter. Same trans as the F2 that is prior to SN 48200. I saw it in there over the winter and asked about it because I have an F2 that is needing transmission work. If I remember correctly the labor on that bill was $2500 to $3000. They may still have some of the parts that were good in both transmissions but I would think that the trans would need to be opened up to replace any of the shafts.
If you have the part numbers that need to be replaced I can check with the service manager or mechanic to get an estimate. I am around home this week helping with wheat harvest and straw baling so I will be able to meet with them face to face instead of by phone. They also have a couple of F-F2 in the boneyard that are mostly complete in the drivetrain area. |
Dans 7080
Posted: 09 Jul 2012 at 9:45pm |
If its just the shaft and sleeve its a piece of cake. Knock the roll pin out of the sleeve and slide the sleeve to the inside and the shaft will come out.
MACK
Posted: 09 Jul 2012 at 10:06pm |
Are you talking about shaft from trans. to final drive or hydro to trans? MACK
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8636 |
Posted: 09 Jul 2012 at 10:28pm |
That's why there are grease zerks on them couplers!
wheatbreeder
Posted: 10 Jul 2012 at 7:11am |
yes it is the shaft from the transmission to the final drives, do i need to remove the tire?
Morley
MACK
Posted: 10 Jul 2012 at 7:59am |
Just drive the role pins out of both coupplers and slide them to the middle. MACK
wheatbreeder
Posted: 10 Jul 2012 at 8:09am |
Thanks Mack
Now I just have to locate the shaft as they are discontinued and Agco is out of stock Morley
soybreedingboy77
Posted: 10 Jul 2012 at 11:05pm |
What is the part number? McCullough Implement has an F2 in the boneyard that probably has the shaft you are looking for. Go to AGCOpartsbooks.comog on as a guest.
SteveM C/IL
Posted: 10 Jul 2012 at 11:34pm |
lot of F2's in the bone yards.Should be an easy find. There are 2 couplers on each shaft.Better be greasing them like the book says. The inner on the rt side is a PITA cause I gotta drop the screen to get to it. O'le Tbran mentioned the importance of greasing couplers years ago.
wheatbreeder
Posted: 13 Jul 2012 at 7:06am |
thank you all for your support found a replacement the shaft and have it installed
Morley
