AC on Antique Pwer mag back page
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: AC on Antique Pwer mag back page
    Posted: 08 Jul 2012 at 12:59am
Just got the latest issue.  What model is the AC on the back page?  Owned by Doug Solinky in Newark, Vt.  Anyone on the forum know anything about it?
Allis Express participant
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 6:43am
John I just got mine last night and saw that tractor. It looks like a unstyled wc but the frontend doesn't. It looks factory to me but I've never seen one before. I wondered if they ever made a wc industrial? Also some interesting reading about the start of the AC B.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 6:50am
Sounds like I better go down and stand by the mailbox !!
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 6:52am
i havent got mine yet. Cry
hopefully it will come today.. Ermm
Edited by acwdwcman - 08 Jul 2012 at 6:54am
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 3:36pm
I wonder if someone made a special front frame cover to mount something.  Among other things, that frame cover sure limits the front axle articulation-----------so I don't think it would have been factory.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 4:06pm
By the looks of it, everything from the oil filter down the shaft to the front wheels is farmer engineered. The front frame rails are cut off short and the front tires appear to be low profile. The steering gear on the outside of the frame is something Allis didn't do on WC's.
 The steering wheel looks like a WF wheel???
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 4:06pm
Interesting how they used an automotive steering box and bypassed the original steering gears altogether.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 4:07pm
Brian, with the frame rails cut off, there is no place for the pedestal to mount and since the steering gear was inside the pedestal they would need to add something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 4:18pm
I think that is a front pedistal rolled 1/4 turn. See the 4 bolt holes on top. They did cut a hole to poke a b type crank through it to start it. Do you suppose the axle pivots on the main shaft of the original steering? I also noticed what Mark said that it doesn't look like it would pivot very far but I think a clear side view might show that the front end sets far enough behind that it will pivot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 4:24pm
I've changed my mind. I don't see the square plate that would be on the top of the pedistal. I do think that it's held on with the cut off part of the frame rails and I can see paint wore off where it hits when it pivots.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 4:26pm
The frame rails are cut off and turned down 90 degrees. The pedestal would have a top cover plate showing and is not that flat. I don't believe any part of the pedestal is in there.
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 6:06pm
Doesnt even  look like there is room to pivot up and down.
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2012 at 10:02pm
check out the grass.  i do hope it's not just a lawn ornament...
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2012 at 10:31am
I'm hoping someone in Vt will drive by and look at it.  Or maybe someone could give them a call to see if the owners know the story.
Did anyone see the "G" pedal tractor at auction on pg 81?  Neat idea, wonder if it is home made or a small run factory toy.
Also, is Benjie Schultz, of "Making Tracks" on pages 92 & 93 a member of our forum?
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2012 at 7:23pm
Lots of farmer engineering, also it has foot operated brakes.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2012 at 8:07pm
You would think the magazine people would know better. Oh well it gives us something to pick a part.
Tongue
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2012 at 8:54pm
Every issue I have gotten from them so far has a tractor similar to the WC in the picture above. Its always a picture of a old tractor that has been sitting outside in the weather, most of the time with little paint left on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2012 at 6:51am
The back cover has been used for Yard Art or Fencerow Finds ever since I've gotten the magazine.
