another ? 433 into D-19
ACMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACMAN Quote  Post ReplyReply Direct Link To This Post Topic: another ? 433 into D-19
    Posted: 07 Jul 2012 at 12:36pm
will this bolt up to my rear plate and what about the flywheel will the D-19 parts work or is there machine shop work needed? tia Bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 2:10pm
haven't done this but studied it some.The combine engine rear plate needs slight mods to fit the tractor but not something you can't do.Drill a hole,trim some metal...something like that.My understanding is that the crank dia is same where flywheel mounts. Don't know how many bolts on a 19(45 used 4 and two pins) but they are all in same location as the 6 on 433. May have to enlarge 19 flywheel holes but I think it's a "bolt up" type of thing. there's a picture out there of a 301 in a 45D and the story is that it was more or less a bolt in deal. Had to use the 45 flywheel and its' bolted to a 301. Like I said,not done this but believe it to very  do-able
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACMAN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 3:22pm
Steve that sounds encouraging I believe I can do that. It is the plan someday as this tractor likes gas better than I like paying for it.lol I know there are newer tractors but this is like an old friend.
