rc timing
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: rc timing
    Posted: 06 Jul 2012 at 3:22pm
what side of the bellhousing do you use to set the timing.thanks for the info
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2012 at 11:58pm
They made real nice timing marks on the flywheel; but they cannot be seen when the engine is installed.
On the FIRE mark on mine you can see where someone has used a chisel to mark the front so it can be seen from the front side with the little cover behind the oil pan removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 12:04am
You can use the set-screw on the crankshaft pulley to find TDC.  It points straight up on the RC engine when pistons 1 and 4 are at TDC, straight at the floor when 2 and 3 are at TDC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 5:28am
so i need to check it at the very bottum of the bellhousing.thanks for the pictures i put a paint mark on mine so i could see it but i could not get the timing light to flash on it on either side that explains why thanks again for the pictures and the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 6:48am
I have never had a "light" on an Allis tractor. Use my ear and listen to the engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2012 at 5:32pm
Im not that talented
