Taking 1 wheel of row crop front end?
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Taking 1 wheel of row crop front end?
    Posted: 30 Jun 2012 at 9:56pm
WD45 row crop - can I take one wheel of the front safely?  I would like to take out snapped off wheel studs.  Does any one have tips how to get hub off spindle?
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:03pm
Shouldn't be a problem. The hub comes of with a nut under the dust cover on hub end. Repack your bearing while it is off. Might be a good time to put new seals and bearings if needed. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:11pm
Thanks, i plan on replacing the bearings and seals as well.  Will the snapped studs be difficult to drill out.  I will use a drill press.  I also have some easy outs to try.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:53pm
Easy outs will NOT work. The studs are splined and pressed in place. So you push them out, when you get the hub exposed you will see the heads of the studs.
NAPA stocks lots of studs. They need to be pressed in place though with a stack of lubricated washers they might pull in with a wheel nut. Pick up some spare nuts when you get the studs.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 11:01pm
I should have called them wheel bolts.  I think they screw in - not stud type.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 11:17pm
 Might be long enough to weld a nut on first. It will work much better than an easy out. Either side will work, as long as threads only are showing. HTH Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:57am
Wheel bolts are exactly opposite of wheel studs. Why did they break?
Gerald J.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:01am
While most wheel bearing covers/dust covers are just pressed in, if I remember right the WD/WD-45 ones are screw on.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 3:38pm
Not sure how they broke.  Some are broken and others have been replaced with a bolt and washers.  I might try and weld onto the back of the bolts.  They are sticking through out the back of the hub.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 7:39pm
WD/WD45 have wheel bolts that screw into the hub, could have broke from being loose and/or shock from front end lifting off ground and dropping as in tractor pulling or hitting a rock. i have taken one wheel at a time off without lifting front, makes it a bit easier if you let the air out of the tire you're removing and pump up the other tire a bit more
R.W View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R.W Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 7:47pm
Good thing you don't have one of those fancy John Deere "Roll-O-Matic" front ends! LOL Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2012 at 9:01pm
Rather than changing the air pressure, why not roll the tire to stay on up on a 4x4, that will give you more than a couple inches clearance for the other with the rigid narrow front.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2012 at 6:02am
Just a 2x4 will work fine. You may want to loosen the lugs first.
Dusty
