C hydraulic lift for belly mower
Larry in Ill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Topic: C hydraulic lift for belly mower
    Posted: 28 Jun 2012 at 12:40pm
Can someone post a few pics of how a belly mower is set up for hydraulic lift.
Thanks,
Larry
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 1:10pm
Here is a pic of my C with the hyd ram and bracket on my SunMastr 60" deck.  Mounts to the foot rest / cross brace (that just broke last night).  I don't have a pic showing the mount better than this, sorry.
Cheers,
Creek
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 1:20pm
I don't have any pictures, but mine has a metal bar that attaches to the torque tube. Where it attaches to the torque tube there is a longer bolt that is also attached to a triangular metal plate about 12 -16 inches on a side with three holes in the corners. The Hydraulic piston is attached to the rear corner and the chain assembly is attached to the front corner. The chain assembly is then attached to the deck. The rear of the mower deck is attached to the Implement bolt holes inside the rear wheels. then the hydraulic piston is activated it raises the deck. This is using a Woods L306. My L59 has the manual Armstrong lift...
I hope this helps. Miles
Edited by MilesGray (CO/KS) - 28 Jun 2012 at 1:22pm
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 2:22pm
If you have a Woods mower it will be as Miles described. I had one on a C . I sold the C and put the mower on my CA. Ordered the lift parts for the CA from a Woods dealer. Sold the one for the C to Lou in PA. I would think that you could still order the one for the C from Woods also.
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 2:40pm
If it's a Woods you can get all the manuals free, go to the Woods web site.
Bill B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 3:26pm
This is just my opinion but, if I had a hydraulic lift set up, I would sell it and buy the hand lift. I have had nothing but a hand lift on the Woods mower and I would hate to think of not being able to raise the deck up any time I want.
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 4:18pm
Here's a photo that might help (not mine), but I'll second Charlie's motion for the hand lift.  Sure is nice to be able to lift the mower anytime I want, even if the tractor isn't running.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 4:20pm
And I believe this is a photo of Charlie's with hand lift, I'm not 100% sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in Ill Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2012 at 6:22pm
Thanks for the pics.  Both look very easy to handle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 9:18am
Charlie and Murph are right - I have the hyd lift and sometimes it is a real pain.  I hit rocks a lot (they grow really well around here) and have to straighten the blades about twice a month.  It would be oh so nice to be able to raise the deck without the engine running and PTO engaged.  I always end up getting a jack instead.  Would be nice for cutting height adjustment as well - some stuff I mow I have to raise the deck a little to clear stuff (rocks), the hyd wants to be all the way up or all the way down, hard to get it to stay in the middle.  The only time the hyd lift is nice is when you see something in the grass ahead of you (garden hose?) and need to get that deck up quick!
cheers,
Creek
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 10:18am
Here is a close up of the Hyd lift on My CA. except I replaced the ram with a piece of pipe. the hyd lift was really usless. the blades have to be turning for it to lift. I replaced the lift on My C with a woods manual lift. If I rember right it was abouty $250 for the manual lift kit. I comes with a large lift spring that  goes from the leading edege of the deck to the torque tube. its easy enough that my wife can lift it with one hand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 6:53pm
I don't use the Woods hand lift on the B cause I have the drawbar lift for a plow on it. Just hook up the chain and goSmile
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 9:52pm
yep, charlie, i do see the value of a hand lift as you recommended for my suburban 12 dozer blade.  i didn't even think of a locking one because my other rear blade small tractor doesn't have that.  so i'll set it up for pedal push (as is) plus hand pull with lockset.
as usual, thanks for xlnt advice.
52 CA, 41 B and a little B1    oh, yeah... and an 8N ford snuck in there, too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 7:53am
It wouldn't be too hard to convert either set-up to use both. Hydraulic for whenever you got things running and hand lift for emergency quick up like when hitting a rock or whatever.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 2:24pm
can someone post a pic of where the bracket bolts to the axles ? does it go in the forward most holes or the rear set where the drawbar goes??   ....Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 5:01pm
Neither set. It bolts up to the 2 sets of threaded holes. The far front and rear holoes are for a pin in the drawbar bracket. The drawbar can be left on in place of spacers behind the mounting flange.
Edited by CTuckerNWIL - 30 Jun 2012 at 5:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 7:50am
Thanks for putting up a pic , as soon as my block comes back from machine shop jail ill be putting the mower on it....Jb
