What was the original paint on a allis
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Topic: What was the original paint on a allis
    Posted: 20 Jun 2012 at 4:41pm
What type of paint did they use when the painted WD's and WD-45's?
Did they prime it first?
Thanks
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 5:04pm
I wrote a blog post about the process. They did prime it and then painted. It was Persian Orange #1 from Dupont that they used.
Edited by Austin(WI) - 20 Jun 2012 at 5:05pm
"Better By Design"
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 8:21pm
The type of paint would have been an alkyd enamel... dupont dulux is an alkyd enamel.
yzfarmgirl28 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yzfarmgirl28 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 8:22pm
Persian 1
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 9:36pm
Austin, I have never seen any evidence of primer paint on any of my tractors from 1935 to 1960.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 10:05pm
I agree with Chuck, I have never seen any sign of primer being used on the pre 65 tractors. The paints that were used in those years was a LEAD BASED paint and didn't need prime as todays paints do. The coverage was better also. Bob
bitburn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitburn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 10:22pm
What paint was used for high temp items like the engine and manifold?
Is there an AC Orange Engine paint, or does everyone use chevy orange?
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 10:38pm
On the 48 WC I'm working on there are some areas have primer and some don't.  The bell housing I'm working on tonight may have been dipped as it was fully covered with red primer, as was the inside of the grill and other areas that either got paint on one side only or maybe no finish paint at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 10:46pm
Austin,
Thanks for the write up. I think I saw it before but forgot about it. Since they could paint a tractor in 8 minutes (2 guys 4 minutes each) they must of had a very high solids paint or used lacquer because is drys very fast!
Pastor Mike
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 10:54pm
I was pressure washing my 1950 C last summer and also found red primer.
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 12:13am
Often castings that need to hold oil were painted inside with an alkyd paint like GE Glyptal that would look like a primer.
Gerald J.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 5:09am
How about the yellow base color that you find?
I have found this on my B and both D12's. Not on the D17 though.
Charlie
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 6:42am
I think the primer on castings was to seal in any sand left over from the casting process.  It would migrate into the oil over time.
1944 Allis C
1960 Allis D-17 LP
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 6:51am
Because cast iron is porous they would prime the inside of castings so oil would not seep through over the years. That's what they told us at mechanics school 20 years ago.
Wink
I am a Russian Bot
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 7:29am
I have from new a WD and D17, neither had primer under the outside paint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 8:07am
We found primer on our tractors that we have restored, but I guess they were D series. So maybe they didn't prime back then.
Edited by Austin(WI) - 21 Jun 2012 at 8:09am
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 8:23am
There is primer on the larger part of our 48 wc both on the cast and on sheet metal. There are also pieces that did not get primer(none on the airbreather).  The peices that do have primer it would be hard to notice if you didn't wire brush and sand by hand.  It is a thin layer of red primer (a lot like rust colour). If it were sandblasted or dunked you'd never see it. It is only noticable in the places where the original finish is well intact. It does not survive long unprotected by the top coat.  I make no assertion this is typical or standard (Kinda like saying the PO1 on my tractor is the real PO1LOL)  But I can say this is the factory original paint.(what little there is)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 5:37am
This is the torque tube on my '63 D12. Typical of the color that I find
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:43am
The wide front I just got for my D17D looks like that. When I stripped off some of the front parts when I overhauled my engine it looked like there was only the original orange. The used combine block was internally coated with Glyptal, but the original one if it was originally I could find no evidence. The glyptal survived the hot tank cleaning very well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:54am
Kinda looks like industrial tractor stock got scavanged to use on ag tractors to keep the line moving. Or maybe shortage of stock primer.  It does show the difference in tractors coming off the line.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:59am
The '39 IB I just got has chipped/peeling paint like above. I thought it had been a yellow tractor, repainted orange. Will have to look closer....
Edited by GlenninPA - 22 Jun 2012 at 7:01am
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 7:19am
I have Found that color on a '48 B, '63 D12, '64 D12 and the '61 D17. Mainly on the torque tubes and block
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 7:47am
It doesn't take a genius to distinguish between the inside and outside a machine. The red primer found on my 50 C was on the outside under the orange paint. Out of curiosity, I checked the 44 C and also found some red under the orange. I didn't say the entire machine was coated in red just that I found some.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 9:27am
That yellow was on the torqe tubes on my D19, my series IV D17 and on Dads series III XT.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 6:27pm
That is primer...all of our D series tractors have them. You will be able to tell if it was the yellow industrial paint under it.
"Better By Design"
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 7:36pm
My 52 CA has red primer under the orange at least on the castings outside as well as inside.
jnicol6600 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jnicol6600 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 7:57pm
My 63 d17 has the same yellow primer as above on the cast parts. Under the heat shield on the left side of the transmission was never orange just yellow
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2012 at 8:24pm
Red Glyptal is more than likely what was on the early bell housings and tranny cases and engine blocks. It probably wasn't meant as much as a primer, but an oil sealant on castings. I would guess, it eventually became easier to dip the castings so it got on all surfaces instead of just sprayed on the inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2012 at 6:41am
a first coat or layer of paint, size, etc., given to any surface as a base, sealer, or the like.
Primer -- a first coat or layer of paint, size, etc./ given to any surface as a base, sealer, or the like.  Point is you all are right  Glyptal / yellow / red, and even PO is primer if more then one coat was applied the original question was if primer was used and clearly it was. Even found grey primer yesterday one the drive shaft cover between the transmission and torque tube.
WC7610 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WC7610 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2012 at 2:35pm
I just read the link posted and there is no mention of primer.  Aside from the castings, I've noticed primer on our WC/WD's
Thanks
