Simplicity Mowers?
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Topic: Simplicity Mowers?
    Posted: 19 Jun 2012 at 9:06pm
What are you guys opinions of the older simplicity mowers? I'm looking to buy one, and just wanted to get you guys's opinions. Thanks!
1950 B, 1952 pulling wd, and 1954 wd45
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 9:36pm
The 7000 Series and the GTHL Series are probably some of the best and most reliable garden tractors ever built.  Lots of attachments and they do the best job of mowing of any garden tractor.  The 900 Series Allis garden tractors are the same except for decals.
I've got an old 917 Allis, a 7790 (diesel) Simplicity, and a Simplicity GTHL-17.  Implements all interchange.  These tractors are also easy to work on.
The one word of caution is that there were some units built with the Kohler Triad V engine.  They have a nasty tendency to blow-up.
Edited by 427435 - 19 Jun 2012 at 9:38pm
Mark
GTH-L Simplicity
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2012 at 10:09pm
i have a simp. 7016H 1978 still running good
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
LoggerLee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 12:28am
I have a 3112H that I like a lot.
WEL(IN&TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WEL(IN&TN) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 5:55am
I have a 17GTH-l large frame tractor/mower. It has the Kohler series II twin cylinder engine. This is a heavy duty unit built to last. As mentioned before, stay away from the Triad engine. They are "junk".
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 6:14am
I have a 7117H that I bought from my FIL. Haven't used it yet. It sat for about 4 years and now has a stuck ring in one cylinder and lacks compression. Pretty new engine in it. A Kohler M18. They are a stout machine. When I worked at the Allis dealership I worked on many lawn mowers and those old Allis 700 and 900 series much better built than the equivalent Cub Cadet or Deere. The hydros were good, the standard gear transmissions were good but I'd stay away from any of the variable speed transmissions that they built for a time. They were high maintenance.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 6:32am
I have an AC 716H (equal to the 7016H Simplicity) which I've built specifically for snow plowing, and man, does that thing push some snow! Wouldn't trade or sell it for the world. On top of that, its a pisser to drive! I have the 16HP Kohler bored & worked over w/E.I. and it has plenty of "grunt" in the "push dept".... Just purchased a set of 26x12x12's rear meats for it.  I'm in the process of building another 716H for my nephew. Great machines, fun to work on. I have a brochure that mentions the weight of one of those units at 806 lbs by itself. Talk bout' heavy duty! With the Dozer blade up front and the weight box out back, no wonder it pushes the way it does!  Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 6:39am
I have two 816Gt units with the twin 16HP B&S, both with the 48" deck cut. A real bear and will eat the grass with no problem. Sandy Lake has had anything I have needed on the shelf and ship quick. If you pick up an older unit without grease zerks in the original spindles, check with Sandy Lake as some models can be upgraded with replacement spindles, or you can drill/tap the originals to make them last.
The one time I put mine into a local shop, they had a number of people ask if it was for sale; the shop owner advised they had to move it away from the newer units they sold as people were were openly comparing the heavier quality of "old vs. new".
With prices of the newer "garden tractor" units, I'll keep the old ones going as long as practical but admit a few of the new zero turns have caught my eye.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 7:17am
I have a 917 H with over 1000 hours. It has the Kohler 2 cylinder opposed engine.
48" mower deck, dozer blade, snow thrower, roto tiller, tire chains, home built plow for installing the electronic dog fence.
Dusty
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 7:29am
I had a 7112 with a 48" mower deck -- it was a great mower !!  the decks were built "deep" and did a excelent job of mowing..
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 12:12pm
What are yall's opinions on the 4211?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 4:22pm
It's a lawn tractor----not a garden tractor.  Built lighter than the large frame models.  It was made to complete with the MTD and Sears type lawn tractors.
Mark
GTH-L Simplicity
WR (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WR (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 7:24pm
I have found Simplicity mowers to be the best I have ever used.  I used to work for people who took care of a 15 acre cemetery.  Let me say that a cemetery is the roughest ground you will find due to backhoes going in and out and graves sinking as the ground settles.  We used Simplicity Sovereigns and Allis-Chalmers 900 Series mowers.  They did a great job mowing and were the most durable thing that we could find.  I went out and bought a 1993 Simplicity Soveriegn with hydro, hydraulic lift and 48 inch deck.  I love it.  I also do my tilling with a 1967 Allis B-112.  Hard to tell how many hours are on it, but it still is going strong and has never been apart yet.  My dad has a 1996 Simplicity Landlord with 1,300 hours on it and other than belts, the only thing he has replaced on it was the fuel pump.  My dad also has a 1980 Allis-Chalmers 914-Shuttle transmission with 48 inch deck.  We lost track of the amount of hours at 3,000 hours but it still mows great.  Hope this helps.  I have always taken pride in the lawns I mow and my own lawn.  A Simplicity or Allis has the finest cut around for the money.  We have had great luck and I hope you do too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 7:33pm
I have a Simplicity 3415 shuttle for sale. I might part it out, the wheels tires will fit my AC 917.
Dusty
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2012 at 8:10pm
I love the job my 4212 (newer version of 4211) does on our ya. Best cut .I have seen yet.
Adam
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 8:52am
Mine being an old farm lawn with lots of pits and dips and sticks and stones will eat in short order any cheap mowers, i know cause it has done it.  I now use only older Simplicity or Allis  products, main mower is a Sunstar (  built like a tank ) my fun mower is a SunRunner  front deck mows almost as good as the Sunstar.  Also have B10 with deck and tiller and am mounting the sickle mower, have a b110 with deck, and a B12 waiting for restoration with a sno blower. A good hard working macines
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 9:08am
I've got a 70 B212 that my dad bought new a year before I was born. It is a 3 speed variable. I have never had problems with the variable but the bevel gear box has been rebuilt a couple times through the years. That would be something to check the slop in when looking at one to buy. Dad did have a couple extra springs on the clutch belt when he pulled it back in the day. It is my tiller machine now as I use a 716H to mow with and have two 314H's waiting to get the blown up Kohlers fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 12:48pm
One last question, the 4211 fell threw. What are yall's opinions on the 3110 with electric start?
Post Options Post Options   Thanks (0) Thanks(0)   Quote LoggerLee Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2012 at 1:50pm
Its a good machine, large frame, sturdy, the bevel gear box is the thing to check.
Far as I know they all had a electric start, they aren't worth a lot of money unless they have attachments.
$450 is about top dollar for the tractor itself if its in AWESOME shape.
This page was generated in 0.077 seconds.
