electrical question-emerg flashers
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Topic: electrical question-emerg flashers
    Posted: 18 Jun 2012 at 8:17pm
Have installed some flood lites and 4 way flashers on a cab tractor of mine.Thought I'd use LED orange marker lites for the flashers (2 at back and 2 at front) . Each LED lite has about 10 LEDs. Problem-can't get them to flash with the lowest power (2 lamp) flasher I could find.
As a test I hooked a conventional lamp in the circuit (50 watt flood) and the draw is enough to make them flash. What's the best answer. I thought of putting a resistor in the circuit but that just creates heat (or is it minimal) . Are there special low draw flashers for LED lites. I thought of putting one of those flashing orange beacons on the cab roof but I'd likely just knock it off with a branch sometime. Anyone else had this issue and what's the fix. Any help always appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 8:22pm
Watch the draw on flasher unit rating , way back had a 57 Chev ans put heavy duty flasher in , would not work as the wattage needed to make it work was not there with the 2 bulbs in the Chev. Might look at a 3 wire flasher where the draw of the unit itself triggers the flasher and the 3 rd lug is the load. I use these on trucks where the tractor at one time might just have 2 lights and with trailer attached have up to 6.
Dale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 8:25pm
My current flasher has the 2 lug  plug harness. How do you wire the 3 lug flasher. I'm kinda electrically challenged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 8:31pm
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 8:59pm
napa sells electronic flashers 2 pin that will do the job 50-262-3 is the part number
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2012 at 11:01pm
Electronic flasher is what you need.
