Hold Position valve disassembly question?
momedic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote momedic Quote  Post ReplyReply Direct Link To This Post Topic: Hold Position valve disassembly question?
    Posted: 16 Jun 2012 at 11:29am
Ive removed the valvr from the pump body. The adjusting screw and spring with the valve ball are out. The issue Im having is after removing both sna rings I can only get the cam shaft out about 1/2", just enough for the other valve ball to come out.
Am I missing something? I assumed to would slide out. I have been using a small socket and banging it from the back side, but still it isnt budging no more than 1/2". Any idea would be great. I really wanna get my hydraulics working.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 6:04pm
I assume you are talking the hold position off a CA or WD/WD45. If so only 2 orings on the cam assembly. Should slide right out after the snap rings are off.The other ball you mention sounds like the detent ball for the handle.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 9:07pm
If it's a WD-45, I just replaced the O-rings in mine a few weeks ago.
It did come apart with some difficulty and I used a brass drift to help it along.
This had not been disaassembled in over 50 years.
