WD45 transmission top plate
Rod Yowell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Topic: WD45 transmission top plate
    Posted: 10 Jun 2012 at 12:50pm
I am trying to put the top shifter plate with the 3 gear forks back on the transmission. Is there a way to tell if the forks are lined up properly? Is it possible to get the plate to seat properly and still not be correctly lined up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 2:17pm
Bump
deereequipment1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote deereequipment1 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 2:23pm
maybe  put the plate in place. If the bolts will tighten, just finger tighten them until you can take the shifter, and go through the gears. If they all shift, they should be lined up ok.
just don't FORCE anything, incase something isn't lined up.
Not sure if taking the shifter out before doing this would help or not.
Raised on a CA,WD,D10 & D15.
Now, proudly own and pull a WD45 high crop, WD45, WC,
also own a D-10, D-12, G and a CA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 2:31pm
don't quote me here but it seems like you put slider and shifter in "R" and top shaft collars in "N" and gently set it in....I think there is some issue with trying to get "R" slider enguaged in fork with everything in "N"....here again,did this before but a long time ago...IT"S NOT ROCKET SCIENCE....you can figure it out.....where is your sence of adventure? Biggest thing is to check that it all works when done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 3:02pm
Ok you shamed me Steve. (lol) I was hoping there was a surefire method to be sure the forks were seated correctly before I bolted it down . So be it. The adventure continues.
RickM(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 7:55pm
Rod, I am in O'Fallon, MO. If you can't get it re-assembled, I may be able to come over to your place and give you a hand. Like Steve said, it works best to put the shift forks into a certain gear and it will go back together pretty easy. I just can't remember which gear but I seem to recall either reverse or second.
Rick
Missouri Allis Chalmers Club Member; 1954 WD45 (NF), 611LTD & 811GT Lawn Tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 11:08pm
....and  Rick might be correct....maybe it's 2nd(collar and fork) which gives room for "R" fork to get down to slider....I dunno but it's somthing like that. If I was standing there looking at the situation I could figure it out.
 The more I think about it, the more I think it needs put in second gear ....
Edited by SteveM C/IL - 10 Jun 2012 at 11:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 11:21pm
The cover has to go on with the left side down first, then roll the reverse fork into place. It won't go straight down into place.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 7:48am
Yes you and Rick are spot on. I have installed the top covers both ways and Charlie is right on the tilting of the cover too. It will go on fast when you get it started down so watch your fingers. lol
Charles (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2012 at 4:57pm
I did mine awhile back and used a info sheet from Sandy Lake Implement.  Following those instructions it was really easy.  They will probably email you the info sheet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 8:58am
So Ron did you get the top cover on? Hope you didn't get a finger in there. lol
 Call me if not. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 3:36pm
I got it on Don. Thanks.  I went through all the gears and it seems to be correct. I haven't started the tractor up yet I still have to pick up the PTO housing tomorrow and put it on. Mike stopped by yesterday and said it seemed to be shifting ok.
Edited by Rod Yowell - 12 Jun 2012 at 6:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 3:37pm
Clap
Edited by Rod Yowell - 12 Jun 2012 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 4:26pm
Rod, glad you got it back on. Now if you misspell a word again, click on post options above your original post and you can go back and change the spelling without make a new replySmile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod Yowell Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 6:04pm
Thanks CTucker. I will keep that in mind.
This page was generated in 0.132 seconds.
