Easy clean-up if there is such a thing
rrambo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrambo Quote  Post ReplyReply Direct Link To This Post Topic: Easy clean-up if there is such a thing
    Posted: 10 Jun 2012 at 8:58am
Is there a preferred/easiest method of cleaning up an old tractor for paint?  Not a full restoration and only the radiator shroud, hood and tank off the tractor.
I would love to redo the whole tractor but don't have the time or money.  Once I get it back together it will be used a lot I hope so I wouldn't want it to be in original condition anyway.
It looks to have a couple of poorly prepared re-paints..  Lots of old paint flaking off in small to large pieces.  I just want it to look halfway decent and protect it from further damage.
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 9:48am
IMO only repainting the shroud, hood, and tank will look worse than the way it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrambo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 9:53am
no..  I'm just saying those are the only pieces that I'm taking off to paint..  the rest will be painted as it sits...  I was thinking pressure wash then go over it with a scotch wheel on my angle grinder...
just wondering what some of you do if you're not doing a full-blown resto...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 10:25am
I call what you want to do a "Preservation restoration".  I soften up the old grease and dirt with a solvent of some kind, old diesel fuel works good, then pressure wash.  I replace badly leaking seals, prime and paint.  Don't look like new, but still parade worthy.
I go over the flaking areas with a wire brush on a disc grinder to remove the loose stuff, and wipe the sheet metal down with paint thinner before painting.  Crude, but works for what I want.  A tractor that you are afraid to use is a waste IMO.
Edited by TedBuiskerN.IL. - 10 Jun 2012 at 10:28am
fwo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fwo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 10:37am
I would go through several cycles of spraying degreaser and pressure washing. I would scrape some of the worst spots with a screwdriver. Then I would rattle can spray it with Rusty Metal Primer. Less than a minute later I would hit it with whatever orange I could find at Tractor Supply. I always keep paint thinner and shop cloths handy and immediately wipe off the overspray. It would look fine and you would have most of it done two hours from now. Smile.
Kindest regards,
F. W. Owen, Homerville, Ohio
http://www.HomerProduceAuction.com
Owenlea Holsteins
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 12:11pm
I spray them down with dollars store spray oven cleaner. DO NOT GET IT ON YOUSELF. then pressure wash. Take a Putty knife to any nooks that didn't come clean and pressure wash again. Wipe down with acetone and paint. The removed sheet metal parts can be done the same hammer the big dents out weld up the holes and paint it. I did mine in two days and it still looks good. You do want to take the fenders off though. they trap moisture and crud at the frame and cause rust. If you don't take them off and paint the rust will be back in a week or two.
Edited by Dakota Dave - 10 Jun 2012 at 3:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrambo Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 12:21pm
really good advice fellows..  I appreciate it.
bitburn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitburn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2012 at 6:46pm
I am in the same situation.   The multiple layers of paint are flaking bad.  In order to prevent the lead paint flakes from contaminating my property I am planning on brushing on uv resistant polyurethane clear coat on the wheels and frame and other parts.  Intending to seal in the flaking paint.  I just pulled the hood and grill shroud off today to start stripping the paint in a more safe manner off site.   Then I am planning on a spray can job.  I figure I need something orange to get me moving.
The only downside, its probably going to take a lot more work to strip the paint later on.
Someday later I'll do a proper spray gun job on the whole tractor.
