What does a D19 weigh?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: What does a D19 weigh?
    Posted: 07 Jun 2012 at 9:25pm
I am looking for an idea what a D19 weighs with a narrow front, no front weight, 9 bolt hubs, with dished rims and 18.4 x 38 tires, and all the hydraulics still on the back and the snap coupler lift arms etc.   Trying to determine what I weigh as it sits so I can see what weight classes I could pull in.
JeffMOnt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeffMOnt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 9:33pm
I would think somewhere just beneath 7000lbs if it's gas. Just over 7000lbs if its a diesel. Really you need to get it on a scale to really know.
Edited by JeffMOnt - 07 Jun 2012 at 9:34pm
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 10:14pm
According to tractordata.com, for a gas D-19 6650lbs for operating weight.
Travis(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2012 at 10:46pm
Doubt this will help much, but my snap coupler WFE diesel with 15.5X38 power shift non fluid filled with 12 segment weights and my 240lbs weighed 8800lbs years ago on the scale when I pulled factory stock
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2012 at 6:33am
Without the rear cast wheel centers you should be real close to 6000 lbs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2012 at 6:44am
6000 lbs.
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2012 at 2:44pm
Just drive over scales and go back to registration table. They should allow you to do that
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2012 at 4:39pm
If that's the case, I might need more suitcase weights.   There is a class coming up this summer that is 8500 at the two local county fairs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 10:22am
My wide front D19D SC unit with 16.9-34 rears (no fluid), 3 front stack weights and 5 gallons of diesel weighed in at 6,790.
You don't want to know how much more with me on it . . . . .
Ricky D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky D Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2012 at 7:07pm
We have a D19 gas w/narrow frt end and 15.9 X 38's on disc wheels, last time i weighed at a pull it was just over 5500 lbs w/me (200 lb) on
This page was generated in 0.840 seconds.
