Glass jar leaking on fuel cup
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: Glass jar leaking on fuel cup
    Posted: 06 Jun 2012 at 12:40am
Any good solution to a good fix. Tried black silicon and let sit for 8 hrs. Was brand new from A&I and was fine for the first 3 times. Ran a little and cleaned out junk. Now wont seal. Frusterated in the new yellow paint of the D 21.
Any suggestions?
Thanks leaking in WA.Cry
Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
MBwcIll View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBwcIll Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:07am
On the last 14 we are working on I need to take the bowl off in order to install the missing side panel.  The bowl would never seal again even after three new gaskets.  Andy put a used houseing on the tank we had, one of gaskets we had been using, the same bowl and it stopped leaking.  Upon looking , the old housing was damaged in the past and by some luck it had been working until I needed to remove the glass.  Perhaps you have the same problem and need to replace your unit all together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:56am
I ran into the same thing on my D17D. Got a new bowl and it leaked worse than the original. Then I noticed the nut on the bail was not centered. Got a 2nd and all is well so far.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:04am
Sometimes there is a slight burr on the glass bowl that needs sanded down. Over tightening can warp the pot metal casting and it will never seal without chucking it up in a lathe and facing the gasket area back flat. You can check the fit of the bowl to the casting without a gasket. If it doesn't fit flat and true, it won't seal.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 8:27am
When tightening the bail, give the sediment bowl a little twist just before it's too tight to do so. That will seat it so it doesn't leak.
Dusty
mmccarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmccarty Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 3:48pm
The silicone will start disintegrating and will clog everything up.  I went to a local small engine shop, bought a small sheet of cork gasket material and cut a new gasket.
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:08pm
yes, CORK is needed anything else will leak
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2012 at 7:24pm
  have a new unit   not that expensive    1-574-342-4545
