WD-45 ammeter shows discharge
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 ammeter shows discharge
    Posted: 04 Jun 2012 at 12:34pm
My WD-45 shows a discharge when I turn on the lights. It was all working fine until I noticed some battery corrosion and decided to clean it up. I am running 6v and did polarize the generator. I cleaned the battery cables, made sure the ground is good and put a new screw in the box holding the switch. I am using heavy enough battery cables for 6v. Everything seems to be good. This does have a newer light switch, but the switch is not a factory one. One I bought on E-pay, but seemed to work. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 12:38pm
The light switch provides the ground circuit for the F terminal on the gen. Ground the F terminal and see what happens. If it charges full rate, pretty good chance your new light switch is not grounded or faulty. Clean all rust from the mounting points of the switch and screws in the box. It'll probably start working.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2012 at 1:41pm
Make sure that new light switch isn't grounding on the inside of the Ammeter box anywhere. From what a lot of our customer's tell me, that aftermarket 3 pos. switch doesn't fit well in some of the OEM boxes..
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2012 at 12:38pm
I will check it again and try grounding the F terminal. I may have to get ahold of Steve for a new switch, but the charging system has been working. It will be a couple of weeks before I am back at my tractor. Thanks
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2012 at 5:14pm
Finally got back to my tractor. Grounded the F terminal and it charges great! Now have to super clean everything in the ammeter box. Thanks again guys for the help.
