Carb gasket for D-14
Charlie (NC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Topic: Carb gasket for D-14
    Posted: 02 Jun 2012 at 12:29pm
Fellows I'm kind of in a bind.  I need a Carb gasket (the one between the two halves of the carb) for my D-14 and I need it quick.   My only hope to get one anywhere local is from Tractor Supply.
The only M-S carb parts they have are for Ford 2N,8N and 9N or for MF TO-20 or TO-30 or
MH 44, 444 & 50 or JD M, MC, MT, 40 and 320. Looking at the pictures on the Tractor Supply web page they are cut out very close to the same if not exact.  I'm 40 miles from the nearest Tractor Supply so I don't want to ride there just to look.
Is there a chance that one of those gaskets is the same as the one in the AC D-14 version
of the M-S carb?  I think mine is a TSX 159.  Is that right?
Thanks
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 1:11pm
 9n 8 n  gasket is the same , you can use the needle and valve also .
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 1:24pm
You can get gasket material and make your own. I made one .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 1:55pm
It's kind of a tough one to make with 10 holes in it of various sizes and shapes.  I was hoping not to have to.  I got lucky.  I found a web site that shows what carb kits
fit what model M-S carbs.  It turns out that all of those I mentioned except the JD models use the same kit and the tractor supply 35 miles down the road has it.
Thanks for the reply.  Here's the web site I found in case someone wants to book mark it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie (NC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2012 at 1:56pm
Thanks Fred,  I didn't see your reply before I posted above.
